Help Nismo 370z LMGT5's Will the 10.5" rear with +23 offset fit a G37? Birmingham AL
#31
Isn't the width spilt by half onto each side of the wheel? Because by your math the width is only going to the outside of wheel. That's why I'd say for every inch you'd knock off about 6mm...
If a wheel is 10 inches wide with +/-0 offset, it'll have 5 inches on each side. If a wheel is 11 inches wide with zero offset, it'll have 5.5 on each side, not 6 on one 5 on the other...
#32
By the way Adrians red car is fantastic! How did he do the hood, what paint over the carbon ?
#33
The rears at 10.5 +23 will be too aggressive
If you want to listen to those running 255 stretched tires with at least neg 3 camber, prepare yourself to buy rear tires every 5 miles with the risk of damage on those beautifull NISMO wheels
If you plan on doing the hella flush look, I think your better off getting a 3 pc wheel. Having rays NISMO wheels with the stretch look just dosent make sense to me. Actually, having any stretched setup on a daily driven car just dosent make sense at all. At least not to me!
#34
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
