20's with drop on G37x??
Old 03-22-2010, 04:44 PM
Vince
Vince's Avatar
I had planned to go back and forth; winter 18"x8 wheels M&S original tires, and summer performance with 19"x8.5 wheels. How it sounds like I'm really screwed, if I go with the eibach. Do you agree or will the 18's work with the springs as well ? Do you know if I'll need an alignment kit with the eibach's ?
Old 03-23-2010, 03:24 PM
tamertantawy
tamertantawy's Avatar
I'm looking to do the same with my sedan but i was thinking of getting 22's. is that overkill?
if i do get 22's what springs should i get?
Old 03-23-2010, 03:25 PM
tamertantawy
btw i have the exact msr's your talking about with a drop but they're 19's. check out my photos
Old 03-24-2010, 01:31 AM
blueborat
blueborat's Avatar
You will be fine with 18inch and springs. My car is using stock wheels and eibach and it works perfectly. I even put on 20mm spacers all around for more flush look. You do need an alignment since your toe can be very off which wears your tires fast. Other than that it is great. 20mm spacers are recommended to avoid the sunken battleship look.
Old 04-25-2010, 06:39 PM
Vince
Vince's Avatar
'havin a tough time deciding on tires for the 19's. Read the C&D artical. Want a performance feal but not too loud or stiff. The PS2's sound good but expensivr. What brand do you recommend?
Old 04-26-2010, 10:03 AM
Vince
Vince's Avatar
There is a eibach camber kit for th rear. It's cheep like $65. Will I need a front camber kit for the front? That is an upper wish bone and it around $450 + labor !!!
Old 05-09-2010, 09:11 PM
G Redline
G Redline's Avatar
quick question, if you go with the sport oem setup for wheels and tires (19's + whatever the wheel profiles are) on the g37x and drop it with eibachs how much wheel gap are we looking at front and back?
Old 05-18-2010, 07:14 PM
Vince
Vince's Avatar
According to the Eibach spec for P/N 6394.140, designed for the 37X, it drops the front 1.9" and rear 1.6".
Old 06-01-2010, 05:27 PM
Vince
Vince's Avatar
So I have the wheels and tires that I wanted on my G37X. I'm ready to go with Pro Kit drop so I call Eibach to make sure that I can get the F/R camber back to EO spec and they tell me I need a kit in front 5.72130K and rear 5.72280K lists for $830. Anyone else need these?
jfisher
04-25-2017 01:22 PM
Falker11
01-11-2016 02:22 PM
jfisher
09-13-2015 07:58 AM
EnYcee-G
09-03-2015 04:35 PM
Quick Reply: 20's with drop on G37x??
