Strut Bar / Sway Bar
Old 02-09-2010, 09:28 PM
GT35R
GT35R's Avatar
Any noticeable cornering advantages when installing aftermarket parts? Does the strut bar make the car feel more rigid? Just curious before i drop 200
Old 02-09-2010, 09:32 PM
gtracing
gtracing's Avatar
can't feel a thing....sway bars are ur best bet
Old 02-09-2010, 10:10 PM
G37Sam
G37Sam's Avatar
Do you track your car?
Old 02-09-2010, 10:17 PM
GT35R
GT35R's Avatar
No I dont
Old 02-09-2010, 10:18 PM
G37Sam
G37Sam's Avatar
Then you're better off with other mods as you won't feel the difference unless you're car is taken to the limit in terms of cornering
A strut bar does look nice under the hood though
Old 02-09-2010, 10:32 PM
Kidcane
Florida G Club
Kidcane's Avatar
Sways made a very noticeable difference. The strut bar made a slightly noticeable difference and does look nice under the hood.
Old 02-09-2010, 11:19 PM
sbmwg37s
sbmwg37s's Avatar
Sway bars will bring a drastic change in handling.
Old 02-09-2010, 11:28 PM
g37RN
g37RN's Avatar
Sway bars and strut bars are perfect for street use. It makes the car so much more enjoyable to drive. Also it looks like you make a post every hour
Old 02-10-2010, 12:20 AM
GT35R
GT35R's Avatar
I dont understand why OEM sway bars are inferior to aftermarket ones. Why wouldn't nissan design our cars with better sway bars.
Old 02-10-2010, 12:34 AM
sbmwg37s
sbmwg37s's Avatar
It's not inferior. It's not stiff enough for some people.
Because the OEM sway bars are desinged to create optimum handling on streets for normal drivers.
Old 02-11-2010, 07:20 PM
xevious10
xevious10's Avatar
Get sway bars Night and day difference
Old 02-11-2010, 08:15 PM
GT35R
GT35R's Avatar
This is what I wanted to hear, excellent. Any brands recommended?
Old 02-12-2010, 08:30 AM
xevious10
xevious10's Avatar
stillen are good Hotchkis are good too. I prefer the stillen ones because they are red and you can see the rear one from behind =)
The stillens don't come with poly urethane bushings so you may want to buy some with some silicone lubricant. They are however the cheaper option even if you do buy the bushing separately.
The hotchkis are just black and come with the bushings but cost about 100 dollars more and the front is adjustable I believe.
Old 02-12-2010, 08:55 AM
JLai
JLai's Avatar
Hotchkis are dark grey. The rear is adjustable, not the front. They're also larger/stiffer than the Stillen's if I'm not mistaken. There are even greasing plugs for easy lube distribution. Well worth the difference IMO.
Old 02-12-2010, 11:24 AM
ucla bruin
ucla bruin's Avatar
I got my Hotchkis from Amplified Motorsports in Monterey Park. You can give them a call and stop by to have it installed.
__________________
Quick Reply: Strut Bar / Sway Bar
