Strut Bar / Sway Bar
Old 02-12-2010, 01:07 PM
finagle69
finagle69's Avatar
Originally Posted by JLai
Hotchkis are dark grey. The rear is adjustable, not the front. They're also larger/stiffer than the Stillen's if I'm not mistaken. There are even greasing plugs for easy lube distribution. Well worth the difference IMO.
Hotchkis are only larger b/c they are hollow. Stillens are solid throughout.
As to which ones are better.. who knows. I have the Stillen set and bought a replacement set of Energy Suspension urethane bushings. I love the way it handles now.
Old 02-12-2010, 01:28 PM
Kidcane
Florida G Club
Kidcane's Avatar
Its a bar and it is under the car. Who cares what color it is and thicker and hollow does not = better. Both are good. Pick the one that is in your budget or is a brand you prefer. There is nothing wrong with either.
Old 02-12-2010, 02:01 PM
QuickSilver08
QuickSilver08's Avatar
If only your logic applied to exhaust systems and other parts as well we could probably have cheaper parts all around.
Forgive the questions from the sway bar rookie but are there different sizes to choose from depending on how hard you push your car? I know to big can be as bad as to small.
Old 02-12-2010, 03:51 PM
finagle69
finagle69's Avatar
There are only 2 sets on the market at present. Stillen's and Hotchkis'. They are a one-size-only product from each shop.
I don't know if anyone on this forum has had both, so probably no one can offer a comparison.
Stillen's set offers adjustable fronts and rears regarding stiffness, where Hotchkis' offers adjustability only in the rear.
Old 02-13-2010, 01:19 AM
JLai
JLai's Avatar
Correct. That's because they were designed that way -->
Originally Posted by Skyline-LEXY
Q) Are solid sway bars stronger hollow sway bars?
Answer: No. Sway bars work off of torsional force (twisting motion). Therefore, the material in the center of a solid bar plays little role in the resistance of torsional force. With this in mind, we have eliminated some of the center material and also moved some to the outside of the tube, where it is most effective. In turn, this produces a sway bar that is lighter in weight and just as stiff, if not stiffer than solid. For example, a 1'3/8" hollow bar is equivalent to a 1'1/4" solid. But the 1'3/8" hollow bar is 6% stiffer and 43% lighter than the 1'1/4" solid.
Front Sway Bar 35mm (Ø1-3/8") Hollow
Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable
Features:
• Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar.
• Lightweight, Durable 1.063 (27mm) Tubular Rear Bar 3 Way Adjustable
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
They are hollow FRONT & REAR
Front are not adjustable
Rear are 3 way adjustable
Old 02-13-2010, 01:51 AM
JLai
JLai's Avatar
I don't think that's true. I only see 1 hole in the front...aka Stillen's is non-adjustable in the front -->
Differences
Hotchkis:
- comes with bushings/lube
- hollow
- larger
- stiffer
- rear is 3 way adjustable
- more expensive
Stillen:
- does not come with bushings/lube
- solid
- smaller
- not as stiff
- rear is 2 way adjustable
- cheaper
Old 02-13-2010, 03:14 AM
sbmwg37s
sbmwg37s's Avatar
I always have doubts if they have done enough R&D..
Stiffer sway bars can make you feel better becaues it change the way the car behaves.
If you look at Hotchkis, the front is 200% stiffer.
The stiffer, the more traction you will lose compensating for less body roll.
This effect becomes greater on streets than tracks because the streets are not even.
So, such a huge increase in front stiffness will lead to understeer on streets.
That's something you should look at when considering sway bars.
Old 02-15-2010, 02:00 PM
finagle69
finagle69's Avatar
Differences
Hotchkis:
- hollow
- larger
- stiffer
- more expensive
Stillen:
- solid
- smaller
- not as stiff
- cheaper
ah, i stand corrected. it's been a while since i put them on. thanks!
Old 02-21-2010, 09:21 AM
xevious10
xevious10's Avatar
Totally agree
Old 02-22-2010, 08:46 AM
ECain18
ECain18's Avatar
Found this on Stillens/Hotchkis Websites for some of their sway bar info:
Stillen:
Front & Rear Kit
Non-Adjustable Front (29% Stiffer)
3-Way Adjustable Rear (37-70% Stiffer)
(Except AWD Models)
Hotchkis:
Specs:
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G37S
+120, 175, 250% Stiffer than Stock G37,
+5, 30, 65% Stiffer than stock G37S
+50, 90, 145% Stiffer than stock G35S
So Quote:
If i drive in PA (where the roads are unquestionably bad in some areas) should I look at getting the stillen or would hotchkis still be ok according to the above postings?
Old 02-26-2010, 03:22 AM
D'oh
D'oh's Avatar
I have Hotchkiss on my 350Z. They are 3 way adjustable on the Z for both front and rear, and have performed very well for ~100,000 miles. However, there are some things to consider:
1. The stiffer the bar, the more that end will tend to slide. Stiffer in front leads to more understeer, while stiffer in rear leads to more oversteer. Typically you want to be stiffer in rear than front since the stock car tends to understeer (not 100% sure if G is that way).
2. The stiffer the bar, the more your ride will suffer. You get better cornering and possibly better balance on smooth surfaces, but on bumpy corners the car can become unsettled if the sway bars are overly stiff.
3. Other parts of the car may not be able to handle the extra load from a stiffer bar. In my Z, after 100,000 miles, both of the rear end link mounting brackets fractured. These are the steel brackets that attach the end links to the suspension. They are only $15.00 or so each, but the car was designed with the stock components in mind, so aftermarket ones always have the potential to cause damage to related components that maybe weren't anticipated to be problem areas initially.
4. Based on the specs above, it looks to me like Hotchkis is evenly balanced for a stock G37, but possibly too stiff in front for a G37S or G35S. The Stillen looks a bit better balanced, but certainly not as significant a difference. If you live with bumpy roads, and don't track often, I'd probably go for the Stillen. I do prefer the overall design of the Hotchkis since they are hollow and lighter and come with more components. The very stiff front makes me a bit nervous though. Maybe you could just install the rear and put it on the lowest or middle setting if you wanted to gain oversteer without compromising the front grip or ride too much.
And just for reference, I looked up the Hotchkis Z sways, and I'm running ~22% stiffer in front and 125% stiffer in the rear.
-D'oh
Old 02-28-2010, 02:33 PM
marty315
marty315's Avatar
Anyone have any links for the best prices on the Stillen Sway bars?
Old 03-01-2010, 11:46 AM
LightsOut
LightsOut's Avatar
I'll be getting the hotchkis sways and I'll be setting the rear in the middle.
Old 03-01-2010, 10:40 PM
  #29
stryker2
stryker2's Avatar
I have the front and rear Hotchkis sway bars on my 08 Sport coupe, with the rear on the stiffest setting, and the car's back end is giving up traction too easily around corners. Cornering quickly is my handling priority, and my car is street driven only. Will adjusting the rear bar to the middle setting (+90% stiffer than stock) be the answer, or should I dial it all the way to the least stiff (still +50% over stock) to achieve the best result? And toward that goal, is the Hotchkis bar on the front helping matters, or would I be better served by going back to the stock front?
Another issue is that the Hotchkis front bar is doing a lot of groaning and creaking over speed bumps, dips, etc.. I had the bushings re-lubed and the noises lessened for a while, but they're back now. I'm wondering if another shot of grease will do it, or whether this is just an issue with poly bushings that I have to learn to live with for higher performance. It wasn't making these noises when I first had it installed.
Old 03-01-2010, 10:51 PM
  #30
sbmwg37s
sbmwg37s's Avatar
Set it to the middle, it will bring some tractions back.
I recommend not to set it all the way to the stiffest especially on streets.
Quick Reply: Strut Bar / Sway Bar
