benefit of coilover vs spings
I'm sure there is a thread about this but i cant find the answer i am looking for ..
I have a g37s and live in PA. While snow isnt common, I do need to prepare my ride for when it does snow. I have already put on blizzaks but I would like to lower my car.
I want to go the eibach pro-kit route as i like the subtle drop and is much cheaper then coilovers. Only drops an inch so should be fine for snow ..i hope
Only reason I would get coilovers is to raise back to stock height in winter so that if it does snow, I wont be a plowtruck.
I assume if I lower every spring and raise every winter, i have to get an alignmen every time right? What would you guys do in my situation?
Another thing to consider, although the Eibach drop is mild, if it snows enough that your dropped G37s on Eibach's is a plowtruck, then chances are you probably shouldnt be out driving a RWD sports car in the first place..... even with Blizzaks.
Thats why I have the G37 coupe, and the wife has a 4WD RAV4.
Another thing to consider is the price. Coilovers are going to make your suspension stiffer than springs. The cheapest coilover set is the tanabes, and they run 900ish. You can set a set of used eibachs for 150ish. If you are just getting coilovers to lower the height and you dont want the increased stiffness of the suspension, then I would definately get used springs and see how it works for a season. If it doesnt work, you can probably sell the springs for about the same price you paid and get your money back on the springs, and then do coilovers in the future.
Or if you do the work yourself, you can always go back to stock height by putting on the stock springs.
I live right around Philly and it used to snow more but the past few seasons it has been pretty mild (excluding the blizzard a few weeks ago).
Thanks for your inputs guys. I am going to try the eibach pro-kit first and see how I fare with that. Coilovers did seem like an overkill but I would have splurged for it, if the benefit was that great. no tracking or racing of any kind for me anyway.
