Car pulls to the right
Old 09-14-2009, 12:44 PM
kieranlavin
kieranlavin's Avatar
I can see shifting affecting the car pulling to the side. If you have two hands on the wheel and take one off to shift, the remaining hand might pull the steering wheel to one side or the other. Don't laugh, I've instructed people on track and seen it first-hand
Old 09-14-2009, 10:18 PM
Jakex1
Jakex1's Avatar
just happened to me today, i braked somewhat hard (not enough to jerk the passenger or anything) and pressed the clutch. Felt the car pulling to the right so i let go of the wheel (car was going about 10-15 mph) and the wheel turned 90degrees to the right in about 3 seconds
Old 09-16-2009, 05:27 PM
vinnys coupe
vinnys coupe's Avatar
Originally Posted by BradManUWF
Which way did you rotate your tires?
Originally Posted by 4DOORFUN
How do you rotate tires on the 6MT when they are staggared? All you can do is swap sides which seems pointless. Actually, I'm not even sure you can do that as they may be directional tires.
Rotated side to side.
Old 09-17-2009, 07:16 PM
chasemyaccord
chasemyaccord's Avatar
That doesn't really do much (assuming you have no camber).
However, you actually CAN cross swap wheels (according to the thread I read). There's some sort of lug on the front that prevents you from swapping, which can be removed.
https://www.myg37.com/forums/wheels-...e-760-a-4.html
Old 09-18-2009, 10:25 PM
vinnys coupe
Yeah when i changed my oil the guy just did it for me. I honestly didnt think it would matter either.
Old 09-19-2009, 05:16 PM
Boomer-Bob
Boomer-Bob's Avatar
Could be a tire that has failed internally? I had that problem on a car years ago. Everything looked good except it pulled. Drove me crazier. %-) Maybe swap the tires/wheels with someone and see if it helps, if all else fails?
Old 09-19-2009, 07:32 PM
JLai
JLai's Avatar
FYI: Stock RE050's are directional. So "swapping" would require them to take the tire off the wheel. You can't just swap the wheels.
superjoey
31
03-22-2023 11:56 PM
WolfSongX
Car Care & Detailing
05-10-2017 07:26 PM
Thedbarz
33
02-09-2016 12:05 AM
bikerjosh
08-19-2015 11:26 PM
Quick Reply: Car pulls to the right
