wider tires?
Old 07-10-2009 | 11:19 PM
iLlmAtIc21390's Avatar
iLlmAtIc21390
wider tires?
I had a question. Would wider tires mean better ride comfort since there is more meat on the tires? I thought the more meat tires have the less vibrations would be heard? Any theories?
Old 07-11-2009 | 12:08 AM
jnguyen's Avatar
jnguyen
I think the wider the tire then the more handling because it has more grip on the ground. More meat also does mean better ride comfort if it's more meat as in thick but I don't think we can run thick and wide tires without rubbing. No clue, hopefully the wheel gurus chime in but it's the weekend so I doubt anyone soon
Old 07-11-2009 | 12:13 AM
Wider tires have a larger contact patch and a shorter (and usually stiffer) sidewall. These factors increase cornering ability but create a harsher less comfortable ride. Worse ride comfort, not better.
Old 07-11-2009 | 02:11 AM
ozzypriest's Avatar
ozzypriest
if you want more comfort, you should get adjustable coilovers, and crank them down to 'buick.' Unless you buy 70r truck tires, tires aren't going to do anything meaningful to the ride. It's mostly in the suspension.
Old 07-11-2009 | 07:04 PM
Loi's Avatar
Loi
I recently upgraded my stock tires to wider tires and GOD! the ride comfort is SOOOO MUCHO better!
Old 07-13-2009 | 05:49 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
+1. There isn't a tire tall enough to make a ride diff but will also fit without rubbing.
Old 07-13-2009 | 07:04 PM
What wider tire size did you put on that rode more comfortable than OEM? Which specific tire?
Old 07-13-2009 | 10:27 PM
MaxdOut's Avatar
MaxdOut
Wider tires also adds rotational weight
Old 07-13-2009 | 10:30 PM
CHI-TOWN G37's Avatar
CHI-TOWN G37
wider tires also hydroplane in the rain
Old 07-20-2009 | 11:20 PM
Vu37's Avatar
Vu37
So how much wider on the rear can we do? like 285/35/19? I was thinking about throwing the 245 up front and doing 285s in the rear
Old 07-20-2009 | 11:55 PM
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
Isn't it true with wider tires your MPG go down than compared to skinny tires?
Old 07-21-2009 | 09:08 AM
DrJones's Avatar
DrJones
+1..... sharper over bumps and road noise is up a bit....
Old 08-04-2009 | 07:32 PM
Loi's Avatar
Loi
Potenza 245/40 front and Mich's Polit 255/40 rear. The michs have very soft sidewalls, that might be the factor.
Old 08-04-2009 | 07:34 PM
w0ady's Avatar
w0ady
i heard wider tires get you more girls, thats why i got them.
Old 08-05-2009 | 07:33 PM
shabbo's Avatar
shabbo
Hope you're right
I just put Yokohama ADVAN sport 245/40/19 XLs s on front and 275/35/19s XLs on rear. I really like the stock wheel designs so didn't want to change those.
The car looks very nice and drives very well. It's too early to compare other aspects but this is an awesome looking tire. I also have the Tanabe NF210 springs so overall ride comfort is the same as the stock Potenzas when those were new.
