Wider Tires...Affect on Gas Mileage?
Thanks to feedback on the forums, I am considering going 245/40-19 (front) and 275/35-19 (rear) for my next set. I'm curious if anyone here has noticed any significant impact on gas mileage running wider tires. Feedback anyone?
Generally people who run wider tires drive harder and have a low baseline MPG to begin with.
Here's the "theory". Wider tires add unsprung weight, which introduces more drivetrain loss, so you effectively put less power to the ground. Thus, to accelerate at the same rate as before, you have to give the car more gas.
In addition, if you get the same model tire, you increase rolling resistance, again, introducing more drivetrain loss.
In reality, it won't make a huge impact for daily driving.
It'd be less than 1-1.5mpg loss, at most or if any...
oh, and if you're looking for an amazing setup (which tires) for 245/275... I HIGHLY suggest trying these tires:
Fronts: http://www.tirerack.com/tires/tires....=Ventus+S1+evo
Rears: http://www.tirerack.com/tires/tires....Eagle+F1+GS-D3
I had the Goodyear F1's mounted in the front and felt a little slippage during fast turns but the rears kept planted. So I changed to the Hankooks just to give it a shot. This combo is amazing. Absolutely no hydroplaning, the road noise is almost non-existent, great reviews on tread wear (haven't had them long enough to tell you personally), both are 280 tread wear (stock potenza's are 140) as well as 98W(load) rated tires with ZR speed ratings, dry grip is amazing with no drama(squealing), and all this for a little under $600! I paid $584.91 total.
You honestly cannot beat that. Better price with a crap ton better performance than the stockers. And if you're wondering why TireRack is closing out the Hankooks, it's because they're making way for the new version of it called the "EVO V12". Never the less, this version is still great.
Anyway, hope this helps
The simple answer is that the wider tires themselves with all other factors being equal will decrease your gas mileage, but not significantly. The only difference is a greater contact patch which = greater amount of friction (traction) and slightly more unsprung weight. Neither in a significant amount to noticeable decrease your mileage in the size you are considering.
Mike is correct, as he often is.
So, by recommending the existing Tire Rack Hankook tire, you are recommending to fellow forumites they buy something less than a current updated model tire.
Thanks for the feedback guys. It's been my experience on other cars that a wider tire has not had any seriously noticeable change in gas mileage, but I've also not gone from a 245 up to a 275, so thanks again.
Actually I'm highly considering the Hankook Ventus V12 Evo K110's. I did consider the S1 evo's then read that the V12 Evo's are better all around.
Not exactly. The Ventus V12 Evo has been out for a while now. But, Tire Rack is not a full-line Hankook dealer and Hankook does not want Tire Rack to carry the V12 Evo. Tire Rack will not be replacing their current Hankook with the V12 Evo.
The information I said was simply passed down to what I was told over the phone
I was reminded that the 370Z comes with 245/40-19 (front) and 275/35-19 (rear) and it's gas mileage isn't much different, plus as Neal said, their appear to be a lot of variables. Overall it seems the answer is that it is very negligable.
