Twitchy steering on the highway
The bottom line here is that the car does not behave the way it did when I first got it.
Therefore something is wrong.
I will do some research -talk to the dealer and an independent shop.
I don't agree that the dealer will do a poorer job than an independent-I spent good money when I bought the car. They don't want me to go away unhappy.
Good luck with this.
I have an 08 G37S with 16,000 miles.
I have alot of trouble keeping the car in a straight line on the highway.
I am constantly correcting the steering. It's really very annoying and makes driving on the highway work.
Could it be worn tires?
A problem with the speed sensitive steering?
Something else?
Thanks for any help.
Something else?
Arm flailing tube man
I experience twitchy steering on certain sections of road. I think it has a lot to do with the low profile tires which can get "caught" in the grooves, irregularities of road surfaces.
i agree with callaway about the low pros i have had them on one of my previously owned car and they would get caught and slip in the direction the grove is leaning towards
I put the rear camber kit on a couple of days ago and haven't been driving my car. I can easily see that the car has way more positive camber and positive toe than before. The rears aren't even and one has neutral camber while the other still has a very slight negative camber. When I took it out for a short drive to the post office today I was shocked at how huge the difference is from how it was before. All over the place and difficult to control to the point of being dangerous. I'm taking it to a shop in the morning to get it aligned to my specs.
When I first got my G I noticed it tended to wonder more then any other car I had. After I talked to a lot of people I discoverd that driving with wide tires, something I hadn't really done before , is a little different than normal narrow tires. These wide one, 245 on front and 275 on rear, are very sensitive to worn groves and ruts in the highway. A lot more so than narrow ones.
My .02 worth.
My .02 worth.
Nope! Do you guys have a death grip on the wheel or something? Yeh, the stearing is sensitive but, its supposed to be. After all, our cars are sports coupes. Try relaxing a little bit. Hold the wheel more like you would a bird and gently guide the vehicle down the road. Works for me!![thewave](https://www.myg37.com/forums/images/smilies/th_wave.gif)
I think your used to driving a solid axle rear wheel drive car, truck or a FWD car... Our G's have 4 wheel independent suspension and give great steering feedback, you will have to 'drive' this car rather than just point it, like lets say an F150. Grooves or uneven pavement make you work more but I love it!
You will get accustom to it. Do keep it aligned also, I have mine re-aligned every 15,000 miles and it drives sweet!
![Coolio](https://www.myg37.com/forums/images/smilies/coolio.gif)
#29
No disrespect, but I don't think you have really personally experienced the twitchy steering that is being discussed on here. If you did, you would know that it's much different than steering feedback or torque steer that is found in FWD. If you held the steering wheel "like a bird" during these situations, I can assure you that you would fly off the road. Not sure why it's so bad on the G37, my 04 G35C was nowhere as bad with this.
#30
Then it must be (could be) alignment issues... But I know a few people coming form driving Honda's and Mazda's that are complaining about the uneven roads pulling the wheel and I've driven a few of their G's and found no problems at all. This is my 3rd G (my 1st. 2nd. gen G), My mom is on her 2nd G (had an 03 now an 08 sedan). and I've driven some friends G's and all the 2nd. gen G's behave basically the same on the roads as far as I can tell by driving. Unless you specify alignment specs, you are going to get some good feedback around these roads in Houston even with a fresh alignment if OEM spec.
