20" LEXANI LSS-10 with tanabe nf210 will it fit???
This is my question ...
vehicle: 2008 LP infiniti g37 Sport 6mt coupe
I am planning on buying
20x8.5 with 25 offset with nankang 245/35/20 tires (front)
20x10 with 40 offset with nankang 375/30/20 tires (rear)
suspension: tanabe nf210
story: the vendor im trying to buy these from swears they will fit, however i called a local place that deals with rim and tires and they said they called lexani and lexani does not make the lss-10 for the 2008 infiniti g37s coupe and that if i want the wheels i would have to put in an order so lexani can make them custom for me to fit my car and it would take 60 days .. apparently it has something to do with the brakes being too large .. im just curious .. because i have seen the lss-5 on infiniti g37s coupe and all he said was he needed wheel spacers for the rear, but i have seen the pictures for those and they fit ... lss-10 are same wheel i believe but more spokes .. if anyone can help me it would be greatly appreciated ... this way i dont make a $2000 mistake ..
THANKS
THANKS
There's a member who also floats on g35nyc with a red G with the ironman modded headlights, he just put on some temporary XXR's, but I believe he previously had some Lexani's on. Someone help out on identifying that guy for rochester.
You no longer need spacers for the Lexani LSS-5. Look here http://www.hpautoworks.com/index.php...oducts_id=4617
If you really like that wheel style. consider the XIX X21 here http://www.hpautoworks.com/index.php...oducts_id=4570
You can also check out Vossen 083s here https://www.myg37.com/forums/brakes-...-required.html Those will need spacers unlike the first two.
yah it is a typo 275/30/20 rear .. and yeah i just needed someone to tell me dont go with the cheapest tire, i will go with yokohama .. also .. the XIX X21 are almost exactly the same however .. the lip is not as big .. which makes me not want them .. i still cant find an exact answer if they fit still looking any help would be appreciated and thank you very much for the suggestions!!!!!! keep em comming
I was in the same boat as you earlier and wanted major lips (5 inches and beyond) with a 5 spoke design on my ride. These are what I found to be a problem when going over my options:
1) They didn't fit the G
2) They would go on but needed spacers
3) If they did fit, I didn't like the design (not 5 spoke or ugly)
4) Loved the Design, Fits the G but simply couldn't justify dropping that much $$ on them with everything else I've got going on
I chose not to drop $4000+ on wheels alone and settled for a set that has a good design in my eyes (very important), Would bolt on directly (no spacers,very important) and had a reasonable average lip size.
My point being that if you've got the $$, then go with a custom fitment from Lexani, Asanti, Auto Couture etc...
If $$ is a factor then you may need to reassess what you must have in your wheels
great point .. however im not looking for super agressive lip .. i want 4" lip rear, i could care less what it is in the front really .. but i have things going on too and i also cant justify spending an outrageous amount on rims and tires .. so ... the lexani's i have found with tires for 2099 shipped locks lugs tires mount balance .. its just the fitment issue that is getting to me ...
that red g in the picture .. i pm'd him and he said his offset is 25 in the front and fitment is perfect .. so im good for the front .. however he says his offset was 38 rear and he needed 10MM spacers ... now .. what is the big deal about spacers .. are they bad? .. if it only cost around 100 for spacers .. i would rather get the wheels i want and get spacers .. why is having no spacers very important????
you will rub in the back with those rims since u need spacers to clear the brakes. if u want to run them u either need a very stretched tire, or a ridiculous amount of negative camber.
i'd look for something else bro.
andy .. thank you very much for all of your help .. the vendor who has given me that price says he went above his lexani rep and called the headquarters in los angeles to get the answer and apparently t he g37s is a special case... they have had so many people calling about the wheels that a seconed mold was more than necessary .. so thank you very much again andy for spending the time to do that for me .. however i have found the wheels with those offsets with yokohoma s tires locks lugs shipped everything for 2200!!!! ..
i will definitly keep you in mind for everything else thanks!!!
