Help How to adjust coilover height?
Old 02-12-2009, 12:45 PM
VIP G
VIP G's Avatar
Just want to make sure I adjust the right thing when I lower my front..
I assume its the 2 big nuts that you need the wrenches to loosen. I think the lower one is the lock and the one above it adjust the height. So I'm guessing I need bring the top one down a few turns then.
Hopefully others with coils can jump in, thanks
Old 02-12-2009, 01:28 PM
finagle69
finagle69's Avatar
you don't want to mess with the preload on the spring. what you want to do is spin the entire shock with coil over it so that it shortens the amount of visible threads.
Old 02-12-2009, 01:34 PM
NJlakeshoreG
NJlakeshoreG's Avatar
the shorter the spring the lower u go....the longer he spring the higher it is...
Old 02-12-2009, 04:00 PM
solopresident
solopresident's Avatar
if you don't know you take it to a shop. plus you will need to realign your car after. take it to a shop so they can measure it and get each side as close as possible.
Old 02-12-2009, 04:15 PM
finagle69
finagle69's Avatar
^true.
i did it all myself and can say that it took a long time to get it all right.
Old 02-12-2009, 08:28 PM
solopresident
just take it to a shop. ive done it many times in my old car and this time i just took it to a good shop. they didn't charge me anything extra b/c i got there at like 7am and did it with an alignment.
Old 02-12-2009, 11:27 PM
NJlakeshoreG
great idea solo...but brian loves to do things himself or give it a go...
bri, also if u decide to do it urself, make sure u count the rings to make sure they are even on both sides...from left to right...
hope this helps at all..
Old 02-12-2009, 11:35 PM
gtracing
gtracing's Avatar
adjusting coilover isn't hard...it's getting it right which is the major concern...
most people think that coilovers are meant to adjust the height of the vehicle, etc etc....that's partially true....coilovers are actually meant to adjust the weight distribution of the vehicle....to correctly set the coilovers, u need to put ur car on 4 scales (one on each wheel) and adjust accordingly until ur car is 50/50 weight distribution..or whatever ur aiming for...
Old 02-12-2009, 11:57 PM
NJlakeshoreG
hes not going for thecorner balancing...he just wants to slam his car thru the ground...
Old 02-13-2009, 01:04 AM
VIP G
VIP G's Avatar
Thank you, that correct, I'm going to try to adjust them tomorrow afternoon like 3pm so I would like some more info on how to do this.
From whats been said I move the ring up higher which makes the spring shorter and that hopefully should slam me further
Old 02-13-2009, 01:27 AM
sahiwal007
sahiwal007's Avatar
VIP slamm the front and post the pics
Old 02-13-2009, 01:36 AM
VIP G
VIP G's Avatar
Attempting to, just need to make sure I know how to lower the front coils
Old 02-13-2009, 10:22 AM
NJlakeshoreG
think about it homie...shorter the spring the lower it goes....but ur ride is gunna suffer worse then now...lol...
Old 02-13-2009, 11:33 AM
VIP G
VIP G's Avatar
I love it stiff bro, the rest of the coil is set stiff as possible..going to be trying it after I get out of class...Also I'll just do what the shop did and measure each side so they are the same
Old 02-13-2009, 11:51 AM
STOOF
STOOF's Avatar
Dont adjust the spring.
loosen the rings on the bottom, then grab the shock cylinder and turn it, before doing this you want to measure the entire length of the coilover. As you turn itll get shorter or longer, so if you want it lower, twist it to make it shorter, constantly measuring. repeat on opposite side, just make sure both sides are the same height.
Quick Reply: Help How to adjust coilover height?
