Just finished R&D on this piece. Took a few revision, but finally have it done.
The front subframe tie brace reinforce the front subframe to the chassis on the 07+ G35/G37 using existing mounting points.
There are two mounting points that are left empty from the factory (2 per side). One are on the front subframe and the other are thread and located on the chassis of the car. Our brace fit perfectly into the 2 points.
Note: This will not work for G35 AWD since the G35 AWD already came with a similar reinforcement brace.
Note: Installation only takes 10 min.
hmm..how much lower will it make underneath my car?? do you think it will hang lower then an aftermarket exhaust??? im lowered too much to give up any more space under there..lol
this brace only extend 1/4" or less from your subframe, so yeah, if you scrap this, you probably will scrap your exhaust system and other parts of the car.
I already scrape my subframe and exhaust. lol no pain no gain baby
