Brake Cooling Ducting...
#46
Steering angle sensor???
The sensor in the wheel hun is the ABS sensor.
#47
#48
Then I hooked up hose and ran it back above the lower control arm. You must make sure that it is zip tied up as high as it will go to aid in not rubbing. You will also need to remove your windshield washer bottle to aid in the installation unless you want to hack it up like the other guy did.
The reason I bent the pipes instead of running in between power steering pipes, is because if you run the pipes through power steering fluid pipes. The pipes going in and out through the coolant get very hot. Will deform or melt your duct. Power steering fluid get extremely hot especially at the racing track.
#49
Good thing mine don't go in between LOL. Actually it runs below the PS lines so I could always insulate it with Heat tape. I might just do that before I hit the track. Did a autox today but I don't think your going to see a big difference unless you are on a road coarse.
timc00k
02-15-2017 10:15 AM
