Hybrid Tanabe springs... whadd'ya think?
Old 06-23-2008, 11:49 AM
I have the Tannabe NF210 for the G37 and love them. The ride is almost like stock, no harshness or bounciness. The drop is almost exactly what I was looking for... almost.
The rears are perfect - they drop the car .7" and eliminate wheeel well gap and it isn't so slammed that I rub or scrape driveways. The front is good but not perfect. It could be a little bit lower to eliminate the Godawful front wheel well gap that every Nissan product ever produced seems to have. My solution? Hybrid Tanabe springs!
The NF210 springs have the same part number for the '08 G37 Coupe and the '07 G35 Sedan (TNF130). They drop the sedan 1" F/ 1.3" R and the coupe 1" F / .7" R. They are listed as "spring rate is raised no more than 5% over stock". The DF210 advertises "spring rate is raised no more than 10-15%" and the part number is TDF130. The drop the '07 G35 Sedan 1.4" F & R. If it the DF210 drops the sedan .4" more in front than the NF210 for the same applicaton, and the part numbers are the same for the NF210 for '08 Coupe and '07 Sedan, does it not stand to reason that the DF210 shoud be the same part number for both, will fit, and will drop the Coupe .4" more in front? I think I'll get a set of DF210 for the '07 Sedan application and just use the front springs to even out the ride height front and rear while keeping the NF210 on the rear.
Make that sense? What do you think?
Old 06-23-2008, 12:33 PM
finagle69
finagle69's Avatar
hmm. sounds plausible. give it a shot!
Old 06-23-2008, 12:37 PM
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
I mixd matchd springs with my maxima for the perfect drop... it worked well... Tein and Eibachs...
Old 06-23-2008, 01:25 PM
J.Oh
J.Oh's Avatar
i need tanabe springs - off topic but where can i get them everyone is out of stock at the moment and i WANT A DAMN DROP NOW!@
do it up with the hybrid and show us the results
Old 06-23-2008, 01:37 PM
jedmonds
jedmonds's Avatar
even ampdmotorsports is out???
Old 06-23-2008, 01:38 PM
I got mine form Amped. Dont know if they are in stock now. HP Autoworks has them.
I'm going to do it! Worst case scenario if I don't like it, I can change back and sell someone the DF210 who wan't a bigger drop.
Old 06-24-2008, 02:21 AM
]\[ /-\ ]\/['s Avatar
and if u do like them...u can sell me ur front NF210 since u wont need them any more...i dont want much of a drop at all....i'm thinking leaving the rear stock ( as i think that height is fine) and just changing the front
Old 06-24-2008, 02:23 AM
Maybe you could detail my car like yours is for them???
Old 06-24-2008, 12:21 PM
hmmm...might not be a bad deal
Old 06-24-2008, 03:00 PM
G35_Diva
G35_Diva's Avatar
Wow, BB that sounds interesting. Did you install your NF210s yourself? Pls don't make me spend any more money. hehe
Old 06-24-2008, 05:43 PM
amoney805
amoney805's Avatar
I love my tanabes too but the front needs atleast another 1/4 of an inch drop. If this works I might do it myself.
Old 06-24-2008, 06:38 PM
GiGGaplease
GiGGaplease's Avatar
good idea.
Old 06-24-2008, 11:33 PM
KahnQuistador
KahnQuistador's Avatar
How will uneven spring rates affect handling?
You're going to see a difference but I'd bet some sways would help.
Old 06-24-2008, 11:57 PM
I think the difference in handling will be minimal because they are only a slight difference in spring rate. If the front is slightly stiffer it should make the car lean more toward understeer.
Front and rear sways are on Betty as soon as they are available from Tanabe.
Old 07-06-2008, 12:33 AM
weave
weave's Avatar
So you going to do this?
I just did my NFs tonight and agree that the rear is perfect....the front is less than it used to be but could go down some more....of course I need to settle more than just tonight to pass final judgment.
Quick Reply: Hybrid Tanabe springs... whadd'ya think?
