Big problems with H&R springs and 20s
Old 03-15-2008, 08:54 AM
  #46
kerls08
kerls08's Avatar
they told me it is 53030
Old 03-15-2008, 01:36 PM
  #47
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
Send your H&Rs to me if your switching...
Old 03-16-2008, 07:14 PM
  #48
kerls08
kerls08's Avatar
I will let you know what happens.
I may.
kerley
Old 03-16-2008, 09:51 PM
  #49
mako159
mako159's Avatar
I had the same problem, except my wheels haven't came in yet.. I was running the stock 19's and it was tuckin tire all the way around.. i was talkin to dean at tire rack, he said that they thought it was 1.2 and 1 also.. i went and tryed to get an alignment and played hell trying to find someone to do it.. after finding a place i found out the the camber in the front was -2.6 and -2.3 in the rear.. way out of spec without any adjustments.. still wait to find a fix for the front.. i went ahead and took the h&r's off and returned them for the eibach, which should be releases in about a week according to eibach.. the front spring is done bein engineered, the rear is almost complete...
hope this helps..
Old 03-16-2008, 10:18 PM
  #50
C@ciQ
C@ciQ's Avatar
did u get the camber kits n toe arms
Old 03-17-2008, 01:16 AM
  #51
TerribleONE453
TerribleONE453's Avatar
no i dont believe he has the camber kits ^
Old 03-17-2008, 08:09 AM
  #52
mako159
mako159's Avatar
Nah I don't have a camber or toe kit.. The way i looked at it, why should i spend an extra 500 for the the stillen rear camber and toe kit when the car is still gonna ride like it has not springs in it.. I spoke with the guys at tire rack and he had recommended getting the kit with the eibachs, but he said i might be able to use the factory adjustments in the rear first.. As soon as i get them in ill fill ya guys in with some details and pics..
Old 03-17-2008, 12:26 PM
  #53
newman183
newman183's Avatar
does anyone have a picture of the piece that they cut off under the fender. When I hit a pot hole I think My fender is rubbing.
Old 03-17-2008, 02:01 PM
  #54
solopresident
solopresident's Avatar
hey you guys are also rubbing in the front?
Old 03-17-2008, 02:59 PM
  #55
IP37
IP37's Avatar
i rubbed once in the front
decided to try it out so i went over a few speed bumps.. rubbed coming down on the last one. i must of had my wheels turned though
Old 03-17-2008, 03:01 PM
  #56
IP37
IP37's Avatar
in the rear.. i just cut the extra metal that didn't need to be there. anything in front of the plastic area where it bolts together i cut off
Old 03-17-2008, 03:38 PM
  #57
C@ciQ
C@ciQ's Avatar
i rub only in the front. potholes
Old 03-17-2008, 05:38 PM
  #58
SkyzDaL1m1T
SkyzDaL1m1T's Avatar
And i was just about to order H&R's until i saw this post.....
Old 03-17-2008, 09:27 PM
  #59
kerls08
kerls08's Avatar
Keeping springs and going down in front tire size to 245 35 20 in BFG.
This should work out ok from my calculations.
I will have 1/2 inch inside walls less and about 5/8 less on each side hopfully equals no rubbing.
The look is so badass.
Old 03-19-2008, 10:44 AM
  #60
mako159
mako159's Avatar
But that still won't fix the alignment issues.. Ur gonna be blowing through tires...
Quick Reply: Big problems with H&R springs and 20s
