TPMS / Aftermarket wheels
So i just put on a set of after market wheels w/ winter tires mounted on them and also got the sensors installed in the rims so my TPMS won't go off, but yesterday they did and I took it to the stealership and they told me I need to get the TPMS re-initialized in order for the sensors to work.
Does anyone know if this is true and if so, will i need to do the same thing again when i put my stock 19's back on for the summer?
FYI - I drive a G37S
Any input would be greatly appreciated, thanks in advance
First ... are you SURE they moved them into your winter set up?
If they they did and they are the same ones from your car, they are already matched to the cars BCU. Drive around a little more ... the light should go off.
