Rear wheel spacer installed!!!
Old 11-23-2007, 03:18 AM
Blk-G35
Blk-G35's Avatar
I just completed installing 15mm wheel spacer on the rear and it definetely looks better and should provide little bit of more camber for cornering as well.
The first spacer took me about 45 minutes but second one only took me 30 min. The hardest part of the installation was removing the stock stud and installing new longer stud for 15mm spacer.
The rear e-brake had to be removed to create clearance for installing the longer stud but it wasn't too bad
Anyways I took some pictures of before and after installation.
Before:
After:
Old 11-23-2007, 03:38 AM
TerribleONE453
TerribleONE453's Avatar
looks good!
Old 11-23-2007, 10:24 AM
G37RacerX
G37RacerX's Avatar
Looks very nice, a noticable improvement in stance. Wheel spacers alone will not change your camber however.
Old 11-23-2007, 12:39 PM
Blk-G35
Blk-G35's Avatar
I believe it did since the height of the wheel fender from ground changed from 25.5" to 25.375". This will be equivallent to installing lowering spring but just not as much.
I'm debating on front spacer as well but not as aggressive as rear something in neighborhood of 10mm.
Old 11-23-2007, 12:42 PM
Wicked_limitz
Wicked_limitz's Avatar
looking good.
Old 11-23-2007, 05:35 PM
solopresident
solopresident's Avatar
spacers scare me for some reason. But good job! Does it drive or handle any better?
Old 11-24-2007, 05:14 PM
gbest03
gbest03's Avatar
I dont think spacers had any affect on ride height, all they do is push the wheels out.
If there was any difference in the height, it most likely was the suspension not being settled after being jacked off the ground.
I'm running 20mm spacers on my FX with no problems.
da mayor
da mayor's Avatar
i like the way it looks..... im w/ u solo about spacers scaring me.
Old 11-24-2007, 06:05 PM
GiGGaplease
GiGGaplease's Avatar
thats what im thinking about doing whatever i get my car. looks a lot better. do you have any pictures of the whole car? thinking about getting vr..
Old 11-25-2007, 01:27 PM
Blk-G35
Blk-G35's Avatar
Here is another picture of wheel spacer installed
Old 11-25-2007, 04:09 PM
sahiwal007
sahiwal007's Avatar
nice, can you take some pics far away?
Old 11-26-2007, 03:28 PM
KAHBOOM
Super Moderator of Pwnage
KAHBOOM's Avatar
How does it handle now? Any difference?
Old 11-26-2007, 04:20 PM
finagle69
finagle69's Avatar
looks great! i was thinking of doing this along with the Eibach Pro kit when it's finally released.
PS, it's not unbelievable that the rear ride height would change. look at the angle the wheel sits before spacer, you'll see that there's a small degree of camber. when you push the wheel out, you're pushing it out, not at 0 degrees, but more like 1-2 degrees, which effectively pushes it UP and out. therefore, once the wheel is on, the contact point of the tire is a little higher than what it once was. did that make sense? it's easier to visualize it.
Old 11-27-2007, 05:38 PM
sahiwal007
sahiwal007's Avatar
^ i think it will be a tad lower with camber?
Old 11-27-2007, 11:19 PM
UNV-IT46
UNV-IT46's Avatar
what was your reason for doing this?
Quick Reply: Rear wheel spacer installed!!!
