tire pressure warning light...
#33
which sensors did you end up buying?
i kind of got lucky and found a set of 3 of the same sensor that the car comes with (40700-jk00b) pretty cheap, but the cheapest I can find them elsewhere so I can buy the 4th one is around 105 shipped
but yea, you have to run it by the dealer to have the sensors paired with the car. a nissan dealership should be able to do it too. and maybe cheaper. not sure how much it will be though
#34
Well, I ran over a good size traingle shaped rock a couple of days ago. Left side both tires. My car has the stock 19s. Thought I would have a flat. Didn't. Light came on though. Checked all the pressures and they a fine.
So if I'm reading this correctly, there is nothing I can do to reset the light? I either wait to see if it goes off or go to the dealer? Is it possible the rock compressed the tire enough to crush the sensor....or maybe just change the pressure so dratically for a second that the sensor(s) is confused?
Thanks for any help.
#35
#36
#38
yeah.. I didn't do that.. I only drove around for like less than 3 miles because I thought once you reached 16 MPH then it will activate and reset by itself. Thanks!
mmnjtwa
09-07-2015 02:27 PM
footballmania32
09-04-2015 03:06 PM
footballmania32
09-04-2015 02:17 PM
