tire pressure warning light...
Did you put on your aftermarket rims yet?
If so, do you even have the tire pressure monitors in them?
If you damaged your TPMS from driving over rocks your tires would be punctured and your rims would be bent way out of shape...
They are mounted like this in the rim...
Did you figure it out yet? Mine has been on for like 3 weeks. The dealership has to reset it with a laptop I guess. I just havent had time to take it in yet. Was wondering if yours was fixed yet. I don't get the flashing signal either. It is just solid all the time.
did you have the dealer pair them with the car?
I really don't think they sensors will work on aftermarket rims. I ripped mine off when I put rims on my G35 light always went on after driving about 50+ miles without stopping. I'm starting to think it's a faulty sensor because it should have gone off by now. There's no way in hell my tires were less than 28psi to begin with and I've put air in em all. I thought for sure it would at least go off temporarily after an ECU reset but sure enough it was still on.
