2010 G37S front sway bar bushings
I'm looking for front sway bar bushings for my 2010 G37s coupe.
I looked on Rockauto and it stated the MOOG K200283 will fit my car. However, when it arrived, it was too small. The bushing did not fully wrapped around the sway bar. I measured my sway bar and the thickness is 27 mm. The MOOG K200283 bushing hole is 25.5 mm.
Anyone ordered aftermarket front sway bar bushings for their G37s coupe 27mm sway bar, and which brand and model works?
Thank you.
Thank you.
Rockauto lists ACDELCO, Moog, and Mevotech front sway bar bushings. I visited each maker's web site and only Mevotech distinguished the S model in their parts search. That part number is what Rockauto shows, but Rockauto also lists the ACDELCO part (non-specific model RWD) as a cross-over number.
Here is a list of Infiniti part numbers, you can order from the web site to get OEM at pretty good prices. They answer the phone and will help you get the S bar parts if you have difficulty with the parts list. You can also cross-shop the part number at your local Infiniti/Nissan dealers to see if they are reasonable.
emyrl
04-08-2018 12:02 PM
ReplicaR
06-21-2017 02:51 PM
mjnoles1
12-18-2015 10:19 PM
BH818
07-14-2013 04:43 PM
