Alignment Results
Alignment Results
I just took my car for an alignment and I got the results. I was not surprise for the front because I haven't bought a kit but the rear was a surprise. I have the SPC kit (camber and Toe)and still it is off.
I have the stagger tires 19x8 for the front and 19x8.5 for the rear from my old G35 coupe sport
My camber after alignment is LR:-1.8, RR:-1.7 and the Toe is LR:0.12 and RR:0.12
Based on your experience what else have you done to bring the car with in specs if that is feasible.
Yeah, something is amiss there, you should have no trouble getting easily in spec both camber & toe. I was dropped 2" prior to my coilovers and camber is -1.0 and toe .08.
Maybe they elongated the slots but put the old toe bolts back in???
And w/ those SPC camber arms you can get camber positive if you want so they can be adjusted much better assuming the entire install is correct.
