brake rotor/pad recommendations
Old 12-06-2017 | 11:07 AM
  #46
TinsleyC's Avatar
TinsleyC
Using the floor jack is not a bad suggestion if I get into a bind. Good tip!
We used a 2' long 1/2 drive cheater bar on the top bolt and it took two of us pulling on it to break it.
So the anti-seize can be used on bolts? I've never used the stuff, but did see in a video it was recommended on the hub face, after cleaning it and before the rotor goes on.
Old 12-06-2017 | 08:19 PM
  #47
takeapieandrun's Avatar
takeapieandrun
I bought those Centric brake pads too, so far they've been great. Check out Amazon warehouse deals, I ended up getting the fronts 60% off because there was a "like new" set available; I'm guessing someone bought the wrong part and returned it, but it's easy to see that a brake pad is unused so I was confident.
Old 12-07-2017 | 12:00 AM
  #48
Yes, that copper-based anti seize can & should be used on bolts that are subject to road salts, and other corrosives, and ones that are torqued down pretty good, especially exhaust & brake fasteners.
Old 12-25-2017 | 06:38 PM
  #49
TinsleyC's Avatar
TinsleyC
Just following up here - so I bought the Centric rotors and pads, but had no time to install them - work is crazy with a security implementation, plus Christmas and family, shopping, etc....
I also needed a new battery and an alignment - so I took the car into a garage to have the work done.
Brake job using my parts - $160. New Everstart 24F battery, $99. Four wheel alignment, $79. Having the car back in 3 hours without a sore back and dirty fingernails - priceless!
Thanks everyone for the help.
Old 12-25-2017 | 06:54 PM
  #50
Cross country X's Avatar
Cross country X
I just did the front and rear brakes and rotors in my 12x sedan about 3k miles ago, I used the Centric cryo treated rotors (not slotted or drilled) and the Akebono Street Performance pads all around and the setup has been fantastic so far. I went through Tirerack and it came to about $480 but it was worth every penny, the braking is much more linear and there is absolutely no wobble at any speed or load, and this has been driving through some serious s@$% weather between Mt. Hood and the Oregon/Nevada high desert, and with a full load of camping gear and supplies. Centric and Akebono seem to really have their products hammered out for the G's, I highly recommend them!
Old 12-25-2017 | 08:27 PM
  #51
Glad to hear a couple success stories^^^Sounds like you found a reasonable shop Tinsley, and saved some time for more fun activities
Tunerz_Store
Drivetrain
58
05-03-2018 11:13 AM
Laguna
11-01-2016 09:58 PM
yshepta
10-22-2016 07:10 AM
Nicholas GM
10-03-2016 11:18 PM
jk315
09-26-2016 06:16 PM
Quick Reply: brake rotor/pad recommendations
