Alignment
You're not changing your suspension geometry so you don't need to get one. If you've hit a jarring pothole (and your G is tracking different), your steering wheel off center, unreasonable tire wear, or you lower your suspension then an alignment is in order. Nevr hurts to get it checked periodically but new wheels w/ aggressive offsets won't change your alignment specs.
SiKHG37 (05-01-2017)
