Want to lower my Vert
#91
You questions were:
"I wonder if this would better for our verts?
Should I be the guinea pig?"
No one answered because no one has tried this. VERY few owners modify their verts and all the options that have been tried have already been posted in this section.
If you are not willing to try something without someone spelling it out for you, you should reconsider modifying your car.
So, your options:
- Try something people have already done and enjoy
- Try something new and share your results
-- We'll likely be able to assist when you run into issues
- Leave the car as is, leave the forum, and do something that's a little less intimidating.
The following 2 users liked this post by kiseliok:
corey.grizzle (12-18-2017),
Trezzay (12-18-2017)
#92
Florida G35 Club Premier Member
If you don’t mind me asking, what spring rate did you go with, and do you like them? I may have to pull the trigger soon on some new suspension as I’m at 110,000 miles on the original suspension. I’m not finding consistent information on spring rates, other than the 12 front / 8.7 rear that the KSports advertise.
#93
^ If it helps, the spring rates for BC vert-specific coilovers are 12F / 10R.
I know because I have a new set for sale cheap in the marketplace
studman (01-28-2018)
#94
At the current rate the only time I have an issue is when doing 70+ and there is a big smooth dip that forces the @ss to drop hard, which only happens once every few months, depending on where you drive. BCs don't have separate adjustments for compression / rebound so you will either have to go with customer COs or play with spring rates.
At some point I might try going with 12/11 - that might be an optimal balance for me between DD and carving the mountains.
#95
The swifts I have on are 12/10. This is a good 'medium' setup, imo. If you like taking it slow and want a softer ride, you can push it to 11/9, but I would not go lower, especially in the rear.
#96
I'm in Charlotte as well. Not a vert driver though. Just a slick top sedan that's waiting for me to install the coil overs and wheels sitting in my garage
Where in Charlotte are you guys @kiseliok & @studman
#98
I’m down by Lake Wylie. I’m installing my BC Coilovers, SPC upper control arms, SPC rear toe bolts, SPL rear camber arms, and the failed lower control arms tomorrow. Then I’ll finish off the install by changing my transmission and diff fluid to Motul. Gonna be a fun day for me.
Have you checked out the Carolina Z Club? I’m a member with them and we just put up our calendar of events for the year. [CZC] Carolina Z Club - Carolina Z Club is the website.
#99
I haven't really met up with anyone specific, but went to a couple of c&c and lkn nissan takeover events. I had some work done at soho so it's good to see those guys at the events as well.
#100
Well, the vert is dropped on BC BR Coilovers with SPC Upper Control Arms in the front.
I’m still playing with getting it to the correct height. I put 20mm spacers on it, but they look like they will be too big once I get the alignment corrected, so I’m taking them off tomorrow. Once I fix the ride height to the final level, I’ll get the alignment done. Then I’ll put the spacers back on and determine what to do. I’m thinking I may need to go down to a 10mm based on what I see.
The BC BR Convertible-specific coilovers definitely are a good setup, as they feel similar to stock when adjusted 2 clicks towards Soft from neutral adjustment.
I had ordered SPL rear camber arms for the car, but the part they would replace does not exist on my car. There is the toe arm and the spring bucket, but no camber arm.
I’ll post up some pictures once I finish getting everything situated... it should be in the next day or two, depending on how the rest of my weekend maintenance goes.
#101
I was curious as to what spl arms you received; to the best of my knowledge no one makes rear camber arms for the vert.
SPC bolts should get you within spec, as long as you aren't dropping too low.
I have a set of 20mm, 15mm, and 5mm spacers I'll be playing around with soon. 15 will likely be the best fit with the stock sport wheels.
#102
#103
The 20mm may work if you aren't dropped, but if you're close to rubbing, they are borderline. I'm curious how the 15mm vs 10mm will work. I'll be finishing up the install tomorrow (gotta lower the front right wheel 1/2") and then trying to get an alignment if Firestone can still fit me in.
@kiseliok - If you're bored tomorrow before the game, feel free to swing by. The wife doesn't get home until the game starts.
#104
Had plans for this morning, plus the weather was complete crap earlier.
I won't be doing anything with the car until it gets warmer, but we can meet up some time soon and I'll grab 15mm spacers for you to try out.
