Help Clutch pedal not returning, 2009 G37
I just drove over 2000 miles, got 60 miles from my door coming home from vacation, no clutch anymore.
Event description: while driving
Shift in to 5th, pedal only half returned.
Shift in to 6th, no return on clutch pedal.
You can move the pedal up and down freely, obviously, whatever has happened, does not disengage the clutch.
Any thoughts ?
Hoggy
Any thoughts ?
Hoggy
Try power bleeding the clutch lines. Eventually you will need to change out the slave but what I found is changing just the master will temporarily fix the solution(went 1 year before my master died again).
you can also try adjusting the screw by the master to see if will hold after power bleeding.
gimmeshelter67
28
11-11-2016 10:38 AM
Omstr818
General Tech Questions
08-11-2016 02:13 PM
