tein vs h&r please help
Old 07-13-2016 | 11:56 AM
quakerroatmeal's Avatar
quakerroatmeal
H&R you'll get annoyed through speed bumps as it sits low. I have them + no camber kit. Sitting at around -2.5 all around with toe in spec. Tires are at 20k now front and rear. I got them flipped inside out so it'd wear out even.
Old 09-11-2016 | 02:58 PM
RWizzle's Avatar
RWizzle
Tein Basis Z
So all in all I realize that getting the Tein Basis Z is basically no different than getting any sort of spring setup with the height adjustment being the only benefit. No dampening adjustments and you still need to get a camber kit (if done properly). With the coilovers and camber kit (front and rear) you are still around $1k..... are there any other options to be able to find a decent set of coilovers that possibly come with a camber kit and dampening option for that same price?
Old 09-11-2016 | 03:30 PM
See reply in other thread. And yes the coilovers are different than going w/ springs (at least on stock dampers). The coilovers are designed to work the way you buy them, the OEM shocks are designed to work w/ OEM springs, any aftermarket spring on an OEM damper is not optimal for the way they are engineered.
RochesterG37x
Picture Share G Sedan
10-24-2019 05:12 PM
g35g37fan
03-30-2016 08:09 PM
xnick101
03-27-2016 10:12 PM
Quick Reply: tein vs h&r please help
