For guys that are low, does your front UCA hit your fender well?
Hi guys,
I was just curious for those guys that are low (tucking tire or more), is the G37 known to have the front upper control arm bottom out or hitting the top of the fender well on bumps when you're too low? I just ask this because I'm used to owning Lexus' which are infamous for this problem. I tried searching around to see if G37 owners had this kind of problem but I couldn't even find one thread where someone complained about this.
So anyone have any input? Do the G37 control arms just have that much more clearance than Lexus'?
Thanks in advance!
Thanks in advance!
If you are so low that there's not sufficient clearance between the arm and the body, yes it will make contact. Every car will if you drop it too much. Nbecause there's physically no room for suspension travel. For most people who lower it a more moderate or "normal" amount, it's not a problem.
If you want to lower beyond what's practical, just do like the other guys do who slam their cars: drive everywhere at 6 mph and only use very small gentle steering inputs.
I mean don't want to be super slammed, hella flush. But prob lower the car so there's no gap between the fender and tire. Do the G37 typically do well at that height? For IS300, you'd be hitting the front UCA on bumps if you didn't have high spring rates
Thanks blnewt. That's what I've been wanting to hear!
