Coilover making rattle sound
I just raised my car by 1 inch and I have stances coilover. I juss noticed this in the morning or when I drive over some bumps I hear something in the rear like rattle and my girlfriend told my when I was doin a 3 point turn she heard something in the rear like rattle? Any can give me advice on how to fix it. Thanks
Oh do u reset the preload? Not really sure how to do that? Do I have to take it out ?
I don't have the true rear coilover set on mine, but you should be able to get it set without having to completely remove them, just remove the lower mounting nut while your G is lifted on stands, with the coilover unloaded you'd adjust it so the spring is compressed aprox 1/4" (the Stance website should have the exact preload in mm) while keeping your coilover height unchanged.
Correct. Have the upper ring just touch the spring (which is up against the upper seat) then tighten to compress the spring a quarter-inch. The second ring is a lock ring. Run it up against the top ring and tighten it. This prevents the spring from forcing the top ring down over time. The bottom ring adjusts your ride height.
When adjusting spring preload and ride height, be sure to have the vehicle in the air. You can wreck the threads if you try to turn the rings with car weight on them.
Like this
Can I juss jack one side up were the rattling sound is? Thanks
09-13-2016 09:55 PM
jroyalty7
04-11-2016 06:45 PM
pawel2009
04-10-2016 11:48 PM
