Tanabe springs front only
Old 04-13-2016, 10:07 AM
G37sGraphite
G37sGraphite's Avatar
Originally Posted by saywat?
Ima be honest and tell yalls that I've used the aluminum spacers sold on ebay that cost $30. One piece hubcentric. I kno u guys have seen it on ebay and it worked fine. No need to spend few hundred on name brand spacers imo. They all the same to me unless u gonna track em then maybe u do need magnesium spacers lol
Doing allot of research on spacers and honestly unless your buying super quality spacers they are not worth the risk. Auto damage damage and personal damage increases the cheaper they are. I think your 20 to 40 thousand dollar car and your life are worth 200 bucks more than some crack in half and lose a wheel at 100 mph ebays....
Old 04-13-2016, 10:18 AM
VenomGT9
VenomGT9's Avatar
^^^and yet people will pay $600 for the cheapest set of wheels possible...smh
Old 04-13-2016, 02:44 PM
saywat?
saywat?'s Avatar
the ones i bought from the US seller is made from t-6 6061 aluminum with anodized silver finish. all i can say is i gave it a try and was very happy. and would do it again
his listing is here
Hub Centric Wheel Spacers ¦ 5x114 3 5x4 5 ¦ 66 1 CB ¦12X1 25 ¦ 1 inch 25mm | eBay
Old 05-03-2016, 11:38 PM
G37sGraphite
Anyone install the Tanabe springs in the front themselves? I was wondering what kind of spring compressor you used...will the Autozone rental work?
Old 05-04-2016, 04:26 PM
Kris9884
Kris9884's Avatar
Yeah, I rented a spring compressor from AutoZone. Check my build thread for my Tein spring install, there's a picture of it on the vice somewhere in there. You just have to tighten down each side evenly back and forth so it doesn't spring out one end and kill you in the face, no big deal.
Old 05-04-2016, 06:57 PM
G37sGraphite
Holy shiz dude your car looks awesome!
I only asked because these things appear to be dual rate springs and have less to grab hold of then a linear spring. Sounds good I will try the Autozone way!
Kris9884 (05-04-2016)
Old 05-09-2016, 02:21 PM
saywat?
saywat?'s Avatar
for those with tanabe nf210 springs in the front when you did the alignment were they able to get the front all green (within specs)? i was expecting to see some red in the camber and green for toe but they were able to get it all within spec. i thought it was kinda weird
Old 05-09-2016, 02:26 PM
VenomGT9
VenomGT9's Avatar
Red in camber is a good thing...lolzzzzzz
Old 05-09-2016, 08:49 PM
G37sGraphite
Did you wait for them to settle? How much did you drop in the front?
Tanabe says it will drop approximately 1 inch so should be able to get all in spec....
Going to put mine in as soon as my clamshell single action spring compressor gets here from Harbor Freight!
Old 05-09-2016, 08:59 PM
saywat?
saywat?'s Avatar
yea i waited about 3 weeks or so. i had them on my g35 and it was out of spec just a little. so thats what i was expecting. i guess the g37 is different. what does it mean when the wheel alignment print out doesnt show the "before" numbers jus the "actual" number readings? does it mean the alignment shop didnt have to do anything?
Old 05-09-2016, 09:57 PM
11G37S
11G37S's Avatar
This help...
https://www.myg37.com/forums/brakes-...or-your-g.html
I love my G now after doing my custom work!
saywat? (05-09-2016)
Old 05-09-2016, 10:06 PM
saywat?
saywat?'s Avatar
oh wow thanks 11g37s. i guess the alignment shop wasnt pulling my leg. i thought it was fishy like they didn't actually do the alignment work or something very koo tanabe nf210s are awesome!
Old 05-10-2016, 05:27 PM
11G37S
11G37S's Avatar
Yeah dude no problem. I don't think mine would have stayed in allowable range without the 1/4" spacer. I absolutely love my setup now and get compliments on it all the time how clean it looks. Nobody knows its dropped but certain people. They only notice the carbon fiber diffuser and exhaust thinking its factory sport model.
Old 05-10-2016, 05:48 PM
  #29
G37sGraphite
Confused, Saywat was questioning if his Tanabe front spring install should be falling into spec..he does not have the spacer you created. How did your thread answer his question? Yours is not a normal Tanabe spring install since you have a 1/4 inch spacer.
Everything I read about the Tanabe springs on the front is that there is no need for a camber kit and that they can be adjusted without.
Its when it drops more than 1 inch + that you have a problem.
Nonetheless, the spacer looks to be a great idea to confirm/guarantee that you will not need a kit. Question, do you notice any noise or anything in particular in ride quality etc with the spacer.?
Finally , can you make me 2 and how much?
Old 05-10-2016, 08:33 PM
  #30
saywat?
saywat?'s Avatar
^with his spacer hes dropped .75" as opposed to 1" with the tanabes in the front. i guess its not enough to throw the camber out of spec at .75" so it helped me to see that at 1" its possible that its still within spec too. which kinda answered my concern bc i was expecting it to be out of spec
Quick Reply: Tanabe springs front only
