Front Suspension Clunk?
Hey all,
I did some searching but couldn't find a straight answer just a lot of conjecture. I've been getting what sounds like a metal on metal clunk from my front driver's side suspension. And I do mean clunk. It sounds exactly like metal *clunking* on metal. It isn't constant, but it tends to happen more at low speeds, especially upon acceleration right after pressing the pedal.
I am lowered on Swifts with an SPC camber kit and I've read that the stock endlinks can't support lowered suspension. I've had the car looked at by my local shop but they couldn't hear anything when they drove it and suggested I bring it back next time it starts happening, but I haven't been around town when it's come back.
Do endlinks sounds like a reasonable conclusion? If so, what's the best way to go about addressing the problem? OEM is cheap but what's the point if they're just going to crap out on me? Thanks all.
I suspect it is your endlinks. Raise car, disconnect links from sway bar, secure links and sway bar using zip ties, take for quick test spin. If the clunking is gone then replace the links. Get the ones with the grease zerk fittings.
When you installed the swifts, did you do your own work or had a shop do it for you?
When I first did my swift's I got a weird clunk as well and couldn't figure out what it was for a couple of weeks. In the end, I found the problem to be the top nut holding the shock in the shock mount.
I did not tighten it enough and under driving conditions it moved a little and made a weird metal clunking noise.
once I tighten them, no more noise.
So, short answer, no it was a shop. I'll see if I can take a look though.
Did some digging and I don't think you can find front end links for the X models. Only thing that seems to be available for them is the rears. Maybe I'll just have to replace them periodically. It's not like they're expensive so no big deal I suppose.
