Need advice on camber kits for G37xS Sedan?
Hi,
I'm gathering the parts I need to lower my 09 G37xS sedan in the spring and have Swifts springs ready to go. I wanted to get camber kits for front and rear to be sure that I do it right but not really sure what I need. (I'm a newb to lowering) I see camber arms, camber bolts, toe bolts. All is a bit confusing to me. I was looking at Eibach stuff.
Can someone tell me what I need assuming camber and toe would be out of spec (part#'s and links would be even better)?
Thanks,
John
Thanks,
John
Most people use SPC. Part numbers below.
Front #72130
Rear #72260
Rears should come with toe bolts as a package.
Front #72130
Rear #72260
Thanks. So for the front and rear, I would need arms and not just bolts? For the rear, I thought I saw just bolts available and people drill out the bracket to allow room to adjust.
Sorry noob question..
The two part numbers I posted will get you front camber arms, rear camber arms, and rear toe bolts. That's all you need.
The other way is to get 2 camber bolts and 2 toe bolts, it's the same part # for both pairs of bolts, but you order 2 kits (costs about $25 per kit). This setup involves elongating both the toe bolt slot and the slot for the camber arm bolt, This will get your G back into spec if you are dropped 2" or less. If you're slammed on coilovers or running deep drop springs like H&Rs you may need the $180 set.
FWIW here's the instructions for the rear bolts
https://www.myg37.com/forums/brakes-...-template.html
G37X GraSdadow
03-31-2016 11:16 AM
dragion
02-23-2016 10:05 PM
