Hard Brake Pedal
Hard Brake Pedal
The initial symptom was the car would shake during the first few miles after start.
Then I noticed I would have to press the brake pedal hard to get it to start. I could barely press it until after it started. Then it would soften up to normal.
Repair guy said the left front caliper was gripping the rotor when the car was off. He replaced the caliper. Still have the problem.
I think there is something in the master cylinder or brake booster area of the car.
Why would there be pressure in the system when the car is off?
^^^ That is the issue. It also creates a large intake leak which will make the car idle very rough.
To test: Remove the large rubber hose from the brake booster and plug it.
Start the car and see if it idles normally. I suspect it will.
Hmmm... in looking at the parts diagram (47210), the check valve may be part of the diaphragm, part number D7210-EY03C, listing for $800 (You didn't state the year of your G, so I assumed 2011)
TeeItHi
12
06-15-2019 11:57 PM
shabbo
23
04-19-2008 12:48 AM
