Lowering springs ( Eibach ) questions
I know there's a lot of these threads but none answer my questions .
There's three different springs , the pro and then the racing ones. I feel like the pro wth the 1.2 inch drop isn't enough to make a big difference. Does any one have the 1.5 inch drop in the front work actually make seem like you lowered it. And any recommendations on spacers if needed.
So would you go with the 1.2 or 1.5 inch drop in the front
You should probably get camber arms for the rear and front regardless if its your daily driver.
Some people said they have gotten 14k miles out of tires without camber kits on those springs which to me is fine because I only drive the car 4-5k a year but to others probably not.
Exactly. There's a reason that this thread has been viewed 130+ times, with probably every single person knowing the answer, and no one is responding. People are tired on answering the same questions over and over when people refuse to search and help their own cause.
blnewt (02-05-2016)
Here's my aligment specs with swift springs witch is a mild spring, I'm at -1.7 of camber on most of my wheels, shouldn't be much wear and toe is in spec all around, this is RWD set up
xjabboi
02-24-2016 08:17 PM
Yung_Buddha
02-06-2016 08:56 AM
