front end rattle solution
First time posting on here. This topic has been covered a few times but I just wanted to share my experience. I've had my 09' g37x coupe for about 2 months so far and for the past month I've been hearing a rattle coming from the passenger side front wheel while traveling down bumpy roads. Last night I decided to jack up the front end, disconnect both sway bar end links, secure the links and the sway bar itself using zip ties and then took it for a test spin. Finally rattle free!!! Just ordered some links from MOOG off of Rock Auto. Part numbers were K750209 and K750210. Hope this helps someone find that annoying rattle.
Pyroclastic Flow
Are the sways aftermarket, please? And how many miles are on your coupe. Just so I have a baseline... (not sure if coupe-to-sedan is 'apples-to-apples')
I have some MOOGs from Rock on my parts shelf at the ready!! LOL
BTW: Welcome to the site and a great early post!!
Thanks,
Sean
Great diagnostic work!!!
Thanks,
Sean
Thanks,
Sean
Have you ran MOOGs on your G?
Pyroclastic Flow
No, I haven't needed to change the links. Waiting for them to make noise. LOL. Since I have an X sedan, there's limited choices for front end-links...and I believe MOOG is OEM anyway for this G.
I do have Whiteline end-links for the rear and those have worked out very well. No pre-load, no noise, perfect fit since they're adjustable.
Sean
