Question about OEM Springs
I have a 2009 G37X and need to know if there is a difference between the OEM springs on the front, and the OEM springs on the back.
I'm getting ready to have my Swift springs replaced. I saved the OEMs and want to put them back on but I need to know which ones go where. I hope all 4 are the same and it makes no difference.
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
**Just confirmed, at least on the RWD (and should be the same on the AWD) the rears are bigger in coil diameter, pretty obvious when you have them side by side, hopefully the AWD will be as obvious. G/L
ZenZiglar (12-22-2015)
I got a little worried about the difference between RWD and AWD so I called the dealer. The parts guy talked to a mechanic and confirmed exactly what blnewt said above. The rears are bigger in diameter.
This will be noticeable during installation because they fit into a "bucket" that holds the springs. The fronts are smaller since they attach to the strut.
For future reference I'll share details about part numbers:
Front start with 54010
Rear start with 55020
