What Rotors & Pads for 2011 G37x
Hi
I recently purchased a used 2011 G37x Sedan
What rotors and pads does the car take for both front and rear? Size? Brand?
Also which brake fluid does the car take and how much of it?
Any other things I should replace when I do my brakes? Any pins or bolts or anything of the like?
What brand of rotors and pads are equivalent or higher than OEM quality but are around the same price? I don't mind paying a bit more
I do not want slotted or vented rotors, just the best plain rotors
I want good stopping power, and not too much dust to be made - I wash the car fairly frequently and have a wheel brush
I usually drive alot in city traffic and make frequent stops and need the brakes to last a decent amount of time
Hi
Here you go, just scroll down to the Centric premium + Hawk HPS pad kit.
https://www.knsbrakes.com/c/car-item...+G37+Sedan+AWD
You should be able to reuse all your hardware, if not, check www.rockauto for brake hardware kits.
As far as fluid I use Valvoline full Synthetic Dot 3/Dot4 and get a quart.
