Help Corroded brake fittings and top of caliper
I am changing my pads and when I took off my wheel I noticed that the fitting on the firewall was pretty badly corroded. Also, my caliper had some surface corrosion and the seals on the pistons where dry. Do I need to do anything about the lines or calipers or is that normal? There is no leaking from the lines themselves. Everything else under there seems to just have the normal wear and corrosion.
Depends if they're brittle and cracking, if so I'd get a new seal kit. Check RockAuto Parts Catalog for caliper repair kits, very affordable. Also check your piston sides (where they slide in the rubber seals) for any heavy corrosion or pits.
