Sedan guys with KW - what heights are you running?
Let us know how it goes. I'm waiting until spring before I put in the spacers and getting corner balance at that time as well. I'm also considering having my suspension shop figure out how to reach the top rear adjustments. Any guesses to where the shock tower exits?
Anyway i'm not sure where you can get to that adjustment without removing the shock. My guess is maybe you can drill through the trunk...maybe try pulling back the trunk liner and see if you can locate the 2 bolts that the shock attaches to that come through the body.
good luck - let me know if they are able to figure out how to reach it.
I assume you have the variant 3 right? How do you have them set and which way are you looking to adjust? I'm just curious...I have the v1 so no adjustments on the shock. I do like how it's set so far though, really like the ride quality as it came from the factory.
Sorry to intrude on your thread.
I installed the KW V1s on my Coupe a few weeks back.
Since then I have adjusted the fronts. Very straight forward and easy. Just use the coilover wrench and turn the collar (after removing the little screw, of course). Simple.
Are the rears the same way?
I did a search and can't find a definite answer.
I saw a Youtube video of an Audi with KW V1s and he had to insert a very long allen wrench from the underneath?
Thanks!
Thanks!
The rears are similar when adjusting height. I have the v3 so i can adjust the damping and rebound which are on the bottom and top of the shocks.
Thanks!
Thanks!
WillCo1 (09-22-2015)
Thanks!
Thanks!
I think the point of that allen wrench is to keep the entire perch from spinning when you use the spanner wrench on the collar.
For our cars the perch sits into 3 metal tabs that sit down from the body of the car. So this keeps the entire perch from spinning when using the spanner on the collar. I know KW instructions say to remove the entire perch to adjust height in the rear but I didn't have any trouble doing it on the car.
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
