Ride Height Does Not Change After Adjusting Coilovers
If the height difference between the L and the R collars are drastically different, then there is probably another underlying problem. The height measurement from L to R should be close.
You are eager to help and usually right in your advice so no biggie. Most coilovers for our cars do adjust that way. Tanabe is a much cheaper design entry level coilover so they don't. Probably the only reason I knew that is because I have them so don't beat yourself up. I'm still gonna throw a thanks on your post because you tried to help.
I don't know why they are that way, but with these Tanabes it seems sometimes you will adjust them a lot and it doesn't change the ride height very much. Also keep in mind that they will still settle a little after driving for a few days so beware that you may have to do more adjustment then.
Hey san~man. I thought so too but after thinking a little more into it, it actually makes some sense given that the gas tank is on the left side and the driver weight is also on the left side.
A little variance is ok, but I guess you need to quantify what you mean when you said "A LOT."
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
