Do we really need a camber kit for TEIN lower spring?
Old 03-03-2015, 12:13 AM
  #31
that g tho
that g tho's Avatar
thank you guys i wish all americans was as nice as you guys you guys really motivated me to go install it i was just scared of scraping but not any more thanks once again.
Old 03-03-2015, 12:36 AM
  #32
Received 4,943 Likes on 4,176 Posts
Once you get them installed wait a week for them to settle, then get it aligned. IMO a camber/toe kit is needed and will pay for itself in worn tires. But whatever way you go just be cautious when approaching steep drives, speed bumps, etc. until you get a feel for how the car handles the obstacles.
It's just another acquired driving skill that comes w/ practice.
that g tho (03-03-2015)
Old 03-03-2015, 09:55 AM
  #33
NewG
NewG's Avatar
Just like BLNEWT said you should get a camber kit for the front and rear. With the rear camber kit I was able to set it at -1.9 and no more. I was trying to get the camber close to stock as possible but the Bolts don't have any more adjustment. Does anyone know what I need to get my rear camber closer to -1.5?? I have SPC front and rear camber kit with Tein S Techs.
Thanks
Old 03-03-2015, 10:24 AM
  #34
Thanks
You'll need the rear toe bolt kit from SPC, if you already have that kit they may not have elongated the slot as per the included template. If you have the rear arms & toe bolts you'll be able to get to zero camber if you want.
Old 03-03-2015, 01:22 PM
  #35
NewG
NewG's Avatar
I have the rear toe bolts and arm. The hole was drilled out with the template and they weren't able to go any less than -1.9 in the rear. If I drill the holes out more will I be able to get closer to -1 of camber? Its just that from what I saw, if they drilled out anymore then there won't be much metal left. I may just do it myself if thats the case. The first time I got the car aligned it was set at -3.5 without drilling out the hole but it made the car handle like crap. Now that I had the holes drilled out and aligned at -1.9 its a lot better! I think if I can get it closer to -1 then it would be that much better. Im running Michelin X ICE which are so soft.
Old 03-03-2015, 03:32 PM
  #36
I wouldn't do any more cutting if they cut it as per the template, the way the bolt is mounted offset in the washer only allows for that amount of travel, cutting any more wouldn't have any effect.
Might want to try another shop, they should be able to get much better IMO.
Old 03-03-2015, 03:38 PM
  #37
NewG
NewG's Avatar
I was there at the shop when they were doing it. From what I saw everything was done correct.
Old 03-03-2015, 05:01 PM
  #38
Well -1.9 is certainly tolerable, and if your toe is in spec you should get decent tread wear. Not sure why they're having such a hard time getting it closer though If there's not another shop that you want to try I'd just go w/ it.
Old 03-03-2015, 07:33 PM
  #39
NewG
NewG's Avatar
I think Ill just stick with it. The Toe is within spec BTW. The negative camber will look good once I put the 20's on.
Old 03-03-2015, 08:18 PM
  #40
Need 4 Speed
Need 4 Speed's Avatar
IF the Toe is within spec then Cool... running camber at-1.9 is not bad compared to what Diego and I ran... 2.8-3.0DOMOFlipping our tires was a every other month deal....
blnewt (03-03-2015)
SBG37
05-05-2022 10:35 AM
Ricio1991
10-17-2018 11:24 PM
Broski28
02-09-2016 11:50 AM
Dillybar12
08-17-2015 04:52 PM
MeatySock
08-14-2015 08:25 AM
Quick Reply: Do we really need a camber kit for TEIN lower spring?
