Help 2009 G37x coupe AWD Rotors and brake pads!
Hey Guys,
So i've been doing a lot of searching and i'm unable to find any info on the 2009 infiniti g37x coupe AWD braking system. I do know that I don't have the S type braking system.. Also have found that the 2010 G37x coupe is different than the 2009 g37x coupe...
If anyone can help me and tell me dimensions of the rotors and pads that would be awesome! I even called infiniti and they are confused which sizes the rotors come in. I'm wanting to upgrade my rotors and pads to drill,slotted rotors.. Still waiting for infiniti to call me back but I thought I would give this a try.
Thanks!
Thanks!
Hey Guys,
Thanks!
Thanks!
Yours has the smallest brakes available~the 320mm front rotors and 307mm rear rotors. In 2010 the AWD coupe (non S) went to 330mm F&R. You should be able to tell pretty easily by looking at your brakes that the fronts are bigger. If by chance you have a late model 2009 they may have the 330mm F&R so if you can't tell that the fronts are bigger than may be the case.
GsUP (07-25-2014)
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
Peter Reynolds
08-06-2015 07:53 PM
