Need Advice on New Suspension! Mainly....
So I have a low milage (under 50K mi) ,08 S model and like it. It is a G35 but I am pretty sure its at least 90% similar suspensionwise. I am contemplating a few things up to and including getting a different car (2011-12 Mustang GT or similarly priced and powered car). If I keep the G, I'd put it through a second round of mods, suspension being first as I feel like stock shocks are giving out and had become floaty at high speeds. Currently I am on Eibach's and 20" MRR wheels running I think 245/275. I do not have a camber kit at the current height and keep toe in the green, and something like -2 camber.
Cost is a big factor.
Most seem to agree that sways and end links are a must so I'd be doing that. That's about $500. On top, here are the options I am contemplating and hoping to keep cost in check and as close to another $500 as possible, but not set in stone:
1. Good INEXPENSIVE coils while staying at the same height.
2. Keeping Eibacks and upgrading the shocks to maybe Koni's or such.
3. Get a different car.
4. Your suggestion as to different suspension mods.
5. Alternative mods. I am open to ideas that may make me want to keep it for another 2 years or so.
A 2011+ Mustang is going to be a big step up in straight line performance. If you want something faster and newer, and don't mind a coupe, it's probably the way to go. I would try and find one with the track package and Brembo brakes if it were me.
If you don't want to swallow a new car payment, I would do the Konis. It's my plan when I get to the 45K mileage range.
I don't think you need upgraded end links with sway bars. I'd skip that, should be able to get sways for ~$300.
It's the drop on a 6 year old suspension with 50K miles that's going to compromise the end-links over time.
At least, that seems to be the consensus of opinion, AFAIK. I'm not even remotely there yet, so I can't say first-hand.
I broke an end link on my Mazda 6s, you'll most definitely know when you snap one
OP, If you keep your G I'd rethink the budget just a bit. Keeping your G will save a lot of money compared to a new car payment. I'd try to bump the coil budget up to about $1100 and consider the Stance SS Coils or just a tad more and get the KW1s, and I'd also get the full F&R camber/toe kit. This might equal 3 car payments but you'd have a solid ride for sure. You could sell the Eibachs to recoup a bit of that budget.
G/L with whatever you decide, those 5.0s are quite compelling.
Endlinks aside, would getting coilovers be that much better than getting adjustable shocks?
Also, it is a 6 year old car so I don't really mind slightly used parts...
Koni's are Made in Germany and have a lifetime warranty. I ran them on my F-body with 1.2" lowering springs and loved them. I don't think there is any absolute data to say one is 'that much better' than the other.
Not many people on here run Koni shocks. You would probably have better luck researching them over on the370z.com. We run the same p/n, so it would be a better place to try and pick up a used set, although the warranty is only good for the first user.
I came across KYB replacements for $315 shipped. They seem to have good reviews when paired with the ProKit that I already have. I drive less than 10K miles per year so if it works like new for another 2 to 3 years I'd rather spend my money on something else than an expensive set of coils and camber kits. I doubt that I'll keep my G for longer than another year or two.
Unless any of you think they aren't up to par, I'm going to get that and some sways.
There are coils over on the 370 board for $700, and someome has Nismo take off shocks for $400. I'd check over there before pulling the trigger on anything.
Can you guess who is lurking for some konis
Soundmike had a pretty good review on KYBs and Swifts, he's a pretty knowledgeable guy and has had quite a few suspension combos over the years. I'd trust his opinion.
Brief review of Swift Mach springs - G35Driver
Lego_Maniac (05-21-2014)
soundmike
I think you'll be pleasantly surprised coming from an OEM set-up. If you want an even better ride, pair it up with Koni Yellows!
G35Driver - View Single Post - Brief review of Swift Mach springs
Stop making me want to buy Konis
Thanks for the link
soundmike
soundmike
The KYBs should be a better setup than OEM especially when paired w/ lowering springs, not Konis but a definite improvement.
