G37 original stock brake life
Old 05-27-2014, 12:05 AM
deadlocked
deadlocked's Avatar
Mine has $30 left to do of
Old 08-20-2014, 05:08 PM
MadIrish
MadIrish's Avatar
I am at about 30k on a 2011 G37X and will be replacing the rears (fronts are fine) this week. Brake distribution is a little different on these (and other modern cars with traction control, AWD, etc) and the old "if the rears go before the front, something is wrong" concept no longer applies. Most of my mileage is 35-50mph on surface roads (with about 20 traffic lights I hit most days, lol). YMMV
Old 03-12-2017, 10:05 PM
prizmeye
prizmeye's Avatar
Post You're Forgetting a MAJOR Factor
Differences between the "base/Journey" models and the Sport (G37S) model can make all the difference in the world(!) The G37S has larger, heavier-duty brakes front and rear that are made by a different manufacturer, so discussing both within the same thread can be deceiving. I have a 2011 G37S and the brakes have 65,250 miles on them, but they DON'T SEEM TO WEAR OUT. I'm a average driver who sometimes drives aggressively, so the brakes sometimes get challenged. I bought replacement pads long ago, but my rotors are clean, braking performance is superb, and NO SQUEAKING. I had a flat on the rear, so I checked the pad thickness, and it still looks great. I'm starting to wonder just WHEN I'll need the new pads!
Old 03-13-2017, 04:16 PM
Surfnazi
Surfnazi's Avatar
500 bucks you can order power stop kit that's 4 slotted cross drilled rotors new hardware and pads
Old 06-26-2022, 05:27 PM
prizmeye
prizmeye's Avatar
Talking Terrific Brakes on the SPORT Model!
*UPDATE*: I now have 115k miles on the ORIGINAL (Nissan) G37S pads! I had a little noise, so I pulled the right front wheel, cleaned the pads and the hardware, and STILL have a pad thickness of ~6 mm! [I'm told new ones start at 10 mm and you replace them at ~3 mm]. I can't tell you how impressed I am with these Akebono brakes! Since I live in sunny Southern California with CONSTANT great weather (shameless plug!), I doubt the rear would wear first due to deployment of traction control, especially since I don't "drift" my car or get totally crazy with it, but I'll post an update if the rear show any issues.
slowbird
08-03-2023 07:54 PM
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
drewfinity
08-20-2015 08:17 PM
Quick Reply: G37 original stock brake life
