Help stock 2009 g37x sedan akebono upgrade
i see, you dont happen to have the banjo bolt specs though do you ?
Im looking for the size x thread for example m16x1.25. I would like to pick it up from autozone first before doing the job because it would suck ALOT if i had everything off and i cant get the shorter banjo bolt.
Bing'd "Banjo Bolt myg37" and found this thread https://www.myg37.com/forums/brakes-...-asp-pads.html
I upgrade to Stoptech Stainless Steel Brake lines and did not need to buy banjo bolts.
Akebono requires 17mm m10 1.0 banjo bolt.
The stock caliper has m10 1.0 20.3mm banjo bolts. That will leak.
Such banjo bolts are available from local auto store for 2-3 bucks each. There are titanium ones cost 8-10 bucks each from performance tuning store.
I used cheap ones. The ap caliper used them.
daonlyillwiz (03-24-2014)
Perfect, thats exactly what i was looking for.
I would upgrade to ss lines but i dont see them being necessary. I just picked up a 2005 mini cooper s that i intend on turning into an autox monster, im just doing this because i already had all the parts heh.
drewfinity
08-20-2015 08:17 PM
Ihtbealexxx
08-09-2015 03:30 AM
