Akebono piston diameters?
This may be a stupid answer, but I hope a general answer helps. I was in there last time I replaced my brake pads and saw the pistons. Each of them looked to be around an inch, maybe 1.25" in diameter. Two on each side of the rotor in the front, one on each side of the rotor on the back.
BTW, I am replacing them with Stoptech "Street Performance" pads. These pads do not squeel nor dust, and are good for 1300 degrees F. They are good for light track and also work for the street, either hot or cold, and they're cheap
Because Racecar
That's exactly what I put in mine. You'll need gloves, needle nosed pliers, small diameter screwdriver, brake pad grease, a small hammer, and caliper cleaner.
Jack up car, take off wheel, use needle nose pliers to remove cotter pin, use small diameter screwdriver to push out the hitch pin, remove the retention clip, pull out old brake pads. Use caliper cleaner to clean out socket, grease new pads, put new pads in, align everything, put clip back in, put pin in, put cotter pin back, wheel back on, done.
There's a detailed DIY with pics in the DIY section.
Garrett
Because Racecar
Please make sure you bed your brakes properly BEFORE driving anywhere important. This is very very important. You need to match your brake pads and rotor surface for maximum "bite". Your brakes will have very little stopping power the first few times you use them. The brake pad swap and bedding procedure is here:
https://www.myg37.com/forums/brakes-...ml#post3205126
https://www.myg37.com/forums/brakes-...and-video.html
ck1109
10-15-2015 11:06 PM
Murkr
09-28-2015 10:45 AM
