Whats a good lowering spring ?
Old 01-15-2014, 04:55 PM
  #31
Tim30250
Tim30250's Avatar
Not mandatory, but my negative camber wasn't able to be set within factory specs without the camber kits, so I did install them. I believe I was about -1.7 up front and -2.2 in the rear. You really don't want much more than about -1.0 to be near the Infiniti recommendation.
Old 01-15-2014, 05:30 PM
  #32
Received 4,943 Likes on 4,176 Posts
Sergio, there's folks that just get by w/ the springs but if you're thinking long term it's a good investment to get the camber/toe kit. Having your alignment as per factory specs and keeping tire wear to a minimum is a good goal to strive for IMO & IME.
The money you save in worn tires will eventually pay for the kit
Old 01-15-2014, 10:17 PM
  #33
Tim30250
Tim30250's Avatar
This is a very obvious and valid point that not enough people discuss. With the price of tires for these cars, the excess wear will definitely be more costly than the camber kits over several years.
Old 01-15-2014, 10:26 PM
  #34
Gio37
Gio37's Avatar
This is why I purchased both F/R SPC camber kits when I got my Eibachs.......didnt want to take a chance with my tires.
Old 02-03-2014, 06:56 PM
  #35
Need 4 Speed
Need 4 Speed's Avatar
My recommendation would be going with the coilovers instead of just springs. It saves a lot of wear and tear on your factory shocks. Yes, they cost a little more $, but having the control over the exact height you want and, depending on what CO system you go with, the damping control, they make up for it.
If you are just looking to drop it ever so slightly though and don't want to go with a full CO system, the H&R and Swift springs are a great option. IMO
jdubg37 (03-14-2014)
Old 02-03-2014, 07:53 PM
  #36
J0KER
J0KER's Avatar
If you lower on Eibach "pro-kit" and get a good alignment than you will not have to get a camber kit....
Someone who knows the car well enough can put the car back into spec and eliminate negative camber so you will not have to suffer the burden of alignment wear!
Old 02-03-2014, 08:43 PM
  #37
Need 4 Speed
Check out my thread for Swift Springs:
https://www.myg37.com/forums/brakes-...torsports.html
Old 02-03-2014, 10:32 PM
  #38
Are you sure you meant H&Rs? Those typically drop pretty deep. Swift, Tanabe, & HTechs seem to be the mildest from all I've seen.
SLEV3N
General Tech Questions
10-17-2015 05:58 PM
filipinowise
Intake and Exhaust
09-24-2015 04:18 PM
Dillybar12
08-17-2015 04:52 PM
MeatySock
08-14-2015 08:25 AM
Rubyq60
08-03-2015 10:36 PM
Quick Reply: Whats a good lowering spring ?
