akebono 2 piece rotors?!!!
Old 12-26-2013 | 03:42 PM
nypaul728's Avatar
nypaul728
any on the forum try the akebono 2 piece rotors? apparently they save 10 lbs a rotor?!!!!!
any reviews?!
thanks
Old 12-26-2013 | 04:37 PM
daonlyillwiz's Avatar
daonlyillwiz
Yea, 2 piece rotors are the best, you have other options to go with such as DBA.
Old 12-26-2013 | 06:04 PM
any reviews?!
thanks
Uh, do you have any information on what Akebono 2 piece rotors you are talking about? This is the first I am hearing of them and I'm quite intrigued. Link?
Old 12-26-2013 | 06:25 PM
daonlyillwiz
Z1 2 Piece Akebono Front Rotors
Old 12-26-2013 | 10:45 PM
Are they in-house rotors that fit Akebono apllications or are they Akebono brand? Sounds like they're fabbed in house.
Old 12-26-2013 | 10:58 PM
daonlyillwiz
Thats what it looks like, but i linked it because i believe thats what the op was talking about
Old 12-27-2013 | 02:09 PM
rmfnla's Avatar
rmfnla
"Being enthusiasts, we kept rotor rebuild cost reasonable without sacrificing top tier performance. "
Sounds in-house to me...
Old 12-27-2013 | 05:57 PM
Most definitely NOT made by Akebono. Hence my surprise at this thread because I was pretty certain that Akebono doesn't manufacture any 2 pc rotors for our application. But apparently that is what Z1 is calling them because they are a replacement for the Akebono OEM rotors. OK...
GQ57s_stein (03-16-2020)
Old 12-27-2013 | 06:21 PM
KNS Brakes's Avatar
KNS Brakes
DBA has had 2 piece rotors for this application for a while now. We've actually sold quite a few of them with no complaints.
Is a 2 piece rotor really that much better? Only if you can afford it.
They are much pricier than their 1 piece counterparts.
-Nick
Old 12-27-2013 | 07:09 PM
So does CZP and the first to make them, Racing Brake. RB makes 2 pc fronts and rears. Expensive, but I like them because of the open slot design.
Old 12-27-2013 | 07:42 PM
Staggered357's Avatar
Staggered357
I picked up a set of the Z1 two piece on the Black Friday sale... They are definitely lighter than the 14" Stoptech drilled and slotted for the Akebono... They supposed to make you stop better also due less rolling inertia... And since it is not one piece cast dissipitate heat better. Getting my calipers repainted soon as they come back they will be installed.
Can't wait to install... Reinstall rather
Old 12-27-2013 | 10:09 PM
Those are gonna look tasty
Old 12-30-2013 | 02:37 PM
rmfnla's Avatar
rmfnla
No way that will make a measurable difference.
They look great, tho...
Old 01-07-2014 | 05:23 PM
viet2100's Avatar
viet2100
Same difference in a 10lb less wheel...It does make a difference.
Old 01-07-2014 | 06:04 PM
Not to get too technical, but losing 10 lbs on a wheel has a greater positive effect than losing 10 lbs on a rotor. Because the barrel of the wheel is further away from the rotational axis of the axle. The further out away from the axis the weight is lost, the greater the benefit. But losing 10 lbs on a rotor closer to the axle still helps quite a bit.
Quick Reply: akebono 2 piece rotors?!!!
