akebono 2 piece rotors?!!!
Old 01-08-2014 | 02:51 AM
RISKY GUY's Avatar
RISKY GUY
Originally Posted by rmfnla
No way that will make a measurable difference.
They look great, tho...
100% wrong, the evo has a 2 PC brembro rotors & pads to increase performance & has less weight than a 1 PC.
Less weight = better response.
Old 01-09-2014 | 07:01 PM
rmfnla's Avatar
rmfnla
Not to get too technical, but losing 10 lbs on a wheel has a greater positive effect than losing 10 lbs on a rotor. Because the barrel of the wheel is further away from the rotational axis of the axle. The further out away from the axis the weight is lost, the greater the benefit. But losing 10 lbs on a rotor closer to the axle still helps quite a bit.
I understand the concept; I was thinking along Black Betty's reasoning, but I guess 10 lbs is enough to make a difference.
Old 01-09-2014 | 07:59 PM
rm2342's Avatar
rm2342
These are not required for street cars. I can see the need if you are tracking your car on a regular basis and need better stopping and unsprung weight savings.
ck1109
10-16-2015 12:06 AM
Kojack
10-09-2015 06:53 PM
faze2988
10-07-2015 01:05 AM
VIVID
09-27-2015 10:45 AM
Allboutcali
09-26-2015 04:43 PM
Quick Reply: akebono 2 piece rotors?!!!
