Improve Handling without Lowering
Old 12-02-2013 | 09:39 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Not all cars have rear sways. But this was still funny.
I didn't say *all* cars! I said HIS car, lol. Hey, unless I know otherwise, I always try to answer people's questions as simply as possible.
Old 12-02-2013 | 09:54 AM
I was chuckling at the question, not your response. Your response was excellent and helpful.
Carry on.
Old 12-02-2013 | 10:24 AM
Darth Kinetic's Avatar
Darth Kinetic
is there a recommended FSTB brand?
Old 12-02-2013 | 10:33 AM
Darth Kinetic
Your car HAS sway bars. They should properly be called *anti*-sway bars, but most people simply refer to them as sway bars. They are simply metal bars that have known flex properties. They connect your driver and passenger side wheels and reduce body roll in a turn. The people above are advising OP to install *aftermarket* anti-sway bars. These are bigger (stiffer) and fight the car's tendency to roll towards the outside when taking an aggressive turn.
Hotchkis, Stillen, and Eibach are the favorites for aftermarket anti-sway bars.
oh, ok, got it
I appreciate the clarity!
Old 12-03-2013 | 03:06 AM
farmurr's Avatar
farmurr
Already mentioned above - Cusco (fits without requiring additional modding) and GTSPEC which will rub if you don't remove the hood liner.
Old 12-03-2013 | 10:16 AM
GoFightNguyen
Because Racecar
To be fair, my cusco FTSB rubbed right in the middle a little bit before I removed my hood liner.
Old 12-03-2013 | 12:16 PM
evil-G-nius's Avatar
evil-G-nius
Does Cusco make any under braces for the G? K or H brace?
Old 12-03-2013 | 12:27 PM
GoFightNguyen
Because Racecar
https://www.google.com/search?q=cusc...m=122&ie=UTF-8
I'm not sure if this is what you're looking for. They make several rear braces for the Infiniti.
Old 12-03-2013 | 08:42 PM
farmurr's Avatar
farmurr
Weird, mine doesn't...
Old 02-15-2014 | 12:02 PM
JoshLandry's Avatar
JoshLandry
does anyone have any of the GTspec under car braces??
Infiniti | www.gtspec.com if they work these should help ALOT
Old 02-15-2014 | 04:20 PM
TVPostSound's Avatar
TVPostSound
Technically, they are called anti-roll bars.
Old 02-15-2014 | 06:21 PM
twin_snails's Avatar
twin_snails
I've got the GT-SPEC rear 6-point brace on my 2010 Sedan. It firms up the rear a bit which is quite nice. It makes the car feel more solid.
I also have a Circuit Sports FSTB (http://www.frsport.com/images/detail...747ff73a00.jpg). Not as nice looking as the GT-SPEC but it's one piece of aluminum which is nice.
I also have Koni Yellows on my sedan with the stock springs and no lowering. It firms up the ride nicely over the stock setup.
Just bought a set of Michelin Pilot Sport AS/3's and they are impressive. The car handles really nicely, although I am now considering a set of Swift springs.
eljoker
Future Models
19
05-30-2022 11:48 AM
phamous
Picture Share G Coupe
09-30-2015 02:15 PM
ArmyBoyd
09-22-2015 08:54 AM
m3clubracer
09-20-2015 09:20 PM
Mattlorentzoe
09-20-2015 09:51 AM
Quick Reply: Improve Handling without Lowering
