Nisssan Akebono Vs Infinit Akebono
Old 09-20-2013 | 03:54 PM
Stoptech Street Pads are also a worthy contender
Old 09-20-2013 | 03:57 PM
nycty's Avatar
nycty
Originally Posted by aktif8
Yup, the xs has the non-sport brakes. Initial bite is probably slightly less than non-sport. The stock non-sport pads bite well, initially, but don't really have much past that. The HPS pads bite with slightly less impact, but stop progressively past that. Get on them, and it STOPS.
You'll see some negative reviews of the HPS pads around the web - don't believe them. People get fooled by the initial bite, and can't get used to the change in modulation you have to adapt to. I have no qualms with recommending them.
Since you're going to be in there, get a set of stainless lines. Helps pedal feel pretty dramatically. (KNS can get those for you too.)
Are you DIYing the install? I can give you a list of parts you need if so!
Its always good to get different feedbacks & opinions from different people. No, i wont be DIYing this myself, will probably be bringing it to a friend whose a mechanic at shop to get everything done. I will probably be putting in some stainless steel lines and changing fluids as well. I wonder how the Goodridge SS lines compare to the Stoptechs SS lines. I like how the Goodridge lines have a lifetime warranty, thats always a plus :P.
ck1109
10-15-2015 11:06 PM
Kojack
10-09-2015 05:53 PM
faze2988
10-07-2015 12:05 AM
VIVID
09-27-2015 09:45 AM
Allboutcali
09-26-2015 03:43 PM
Quick Reply: Nisssan Akebono Vs Infinit Akebono
